Gen Set Mobile or Stationary?
   / Gen Set Mobile or Stationary? #1
MF243RedTop
Gold Member
Statesboro, Georgia
Massey Ferguson 243
During hurricane Matthew we got this gen directly from Briggs.. no wheel kit.. but since the wifey worked there only $500 ...
Looked into a wheel kit.. they wanted over a $100 bucks... Not happening for a couple of tires, rod and hardware.
Came up with this caster setup instead.. already had the casters and wood..
Works great for me.. no picking up and pulling it . Just tow along.. just used some 2 strap metal conduit holders on opposite corners to hold gen in place on cart. Could've used bolts but wanted easily removed if needed.
   / Gen Set Mobile or Stationary? #2
Looks like it should be able to roll just about anywhere...
I have used the cheap Harbor Freight 4-wheel dollies but the wheels are smaller and cheaper.
   / Gen Set Mobile or Stationary? #3
Similar situation to me... I simply bought a large-ish metal 'garden cart' (like a "Radio Flyer" wagon).
I had a local metal-shop knock up a detachable, drop-pin, hitch for the handle and can easily use the lawn tractor to move the unit around the property as needed.
Plus, I can always lift the genny off and have a garden cart for use around the property.
   / Gen Set Mobile or Stationary? #4
I have thought of doing this. I would have thought the vibration of the running engine would move the unit around during use? Do you chock the wheels or something?
You can if that's a concern but they stay in place on the ground when running it. The ground around here is all soft loamy soil and flat.
I have nothing to worry about with it moving around.
If you ran it on hard pack ground with a slope then that would be a concern.
   / Gen Set Mobile or Stationary? #6
I've never had to chock as the tyres are rubber/inflated which absorbs any vibration. The cart hasn't moved anytime I've used it. Mind you, my land is flat.
I do employ a grounding stake/grounding wire when using the genny on the cart.
   / Gen Set Mobile or Stationary? #7
Many years back I picked up an ETQ 8250 (company now gone). It came with two wheels, but I added a shaft and two more wheels for under $20 or so. No steering though, all fixed which means I have to lift one end to turn it, or just drag one end sideways a bit. I can pull it with a lawn tractor over grass OK.
   / Gen Set Mobile or Stationary? #8
The question of mobile or fixed is easily answered: Trailer hitch with ball and some 30 mph tires (as on my splitter). Useful out in the field, over to a friends or neighbors, and safer to fuel, away from the building.
I think you missed the point here...
but yeah that's a really nice setup.
Mower deck storage axles
Mower deck storage...
7021 (A55851)
7021 (A55851)
Preliminary Listing / Full Catalog Coming Soon! (A60462)
Preliminary...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A60430)
2013 CHEVROLET...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
