Performance
   / Performance #1
Russ5160
Member
I purchased a new Kioti 2610SE. The performance is kind of lack luster. While finish mowing(60inch) and going up a slight incline(mid range) the engine dies. Can anyone recommend a remedy?
   / Performance #2
You are just running out of HP. The real remedy is a higher HP tractor.
The work around is low range for mowing up hill or not pushing the HST pedal down so far when climbing the hill. It takes time to learn the limitations of any machine but most will do what you need. Some will just do it faster. Good luck!
   / Performance #3
Hills/slope it wiser to use lower gear easier on tractor and safer on you.
   / Performance #4
Right here is your answer
   / Performance #5
I'm not sure what HP the SE / Cab / AC on-off etc., would take away from the 2610, I do know when I had use of a CK2610 for a few weeks waiting for my CK3510SE, it easily handled the finish mower - incline made no difference, couple of things in operation may effect it; I'm assuming you are not using the link pedal, and you are setting throttle at the 540 RPM mark not the 540E mark - I do not know how high the grass was, certainly do not know what the incline was, but the 2610 that I used had no issues with the mower at all, never even considered low range - mid was always more than enough...
   / Performance #6
Russ5160, I'm thinking your CK2610SE should handle the 60" cutter in mid-range on moderate grades without lugging down, except in very tall grass. As K5lwq suggests, try easing up on the HST pedal when you sense the rpms starting to drop. Let us know if that helps.
   / Performance
There is something wrong. I had my grandson out the other day and pulled him behind the tractor in a plastic toboggan full, RPMs and the engine stumbles. Even letting up on the HST pedal it takes a while to regain the RPMs. There must be something i can do. Any ideas?
   / Performance #8
Seems like there is definitely a problem with a brand new tractor; (which really should have been caught during 'make ready') why not take it back to the dealer and make a warranty claim? Are there any other 2610's on the dealer's lot? If there are, compare their performance to yours.
   / Performance #9
Was the tractor fully warmed up? My NX really stumbles when cold. Tractor runs lean. Goes away once at operating temps. This can take 15 minutes some days.
   / Performance
I think I might take it back under warranty issues. I’m not really impressed with their service department though.
HYD LIVE STOCK FEEDER (A54756)
HYD LIVE STOCK...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRK (A51406)
2014 INTERNATIONAL...
