My New Kubota ZD1211 Mower
   / My New Kubota ZD1211 Mower #251
That grass is not tall enough to mow and you are out flogging around in the slop?
You do not need new tires, you need a hobby.
   / My New Kubota ZD1211 Mower #252
ZD1211R constantly getting stuck. Tires load up with mud and spin.
Anyone changed to a different tire? ...
No but I completely fluid filled mine & made a world of difference in mine.
   / My New Kubota ZD1211 Mower #253
They do get poor traction. How much weight is added with loading tires? Does it seem to strain the mower much ?!
   / My New Kubota ZD1211 Mower #254
It adds roughly 100lbs per tire.
It robs a little power only when your climbing Steep Banks.
I wouldn’t suggest this on a lesser Gas powered machine with hyd pump driven wheels.
The ZD diesel with a transmission handles it fine but I’m Super Easy changing directions & starting off from a dead stop.
   / My New Kubota ZD1211 Mower #255
I got rid of the crappy turf tires on my 60" Toro Titan HD 2000 and put bar tires on it. I now can mow through slightly damp grass without getting stuck or marking the ground.
In fact, I mark the ground less with bar tires than I did with the turf tires. Can't believe dealers aren't offering bar tires as an option when selling new.
We got a "recall" notice on our Kubota ZD1211 mower that I'm going to get checked out. Evidently .. a few of their radiator overflow tanks have mis-formed outlets on the bottom hose connection. The dealer says they can check it .. on the trailer so .. I won't have to unload, unless it needs to be replaced.
Anyone else get the notice?
   / My New Kubota ZD1211 Mower #257
My recall was on the reservoir yellow cap.
Yep, that was a year or so ago. This is new and possibly doesn't apply to your S/N.
"The purpose of this communication is to inform you of an important update for your Kubota model ZD1211RL-72R with the serial number 20140. Please contact your Kubota Dealer, W. A. VIRNAU & SONS INC., at (979) 885-3549, and reference bulletin PSB-2019-141 ZD Reserve Tank Nozzle for further guidance and to arrange a time to have this campaign performed at no cost to you. If you have recently had this repair performed, please disregard this notice."""
   / My New Kubota ZD1211 Mower #259
Dealer went to each owners house for This where I am. The bottom outlet of overflow was not made correctly on some units. So they have to run a drill bit through hole to open it to correct size.
If drill bit they have doesn’t slide through hole by hand, they have to drain tank and remove it then drill out and re-install
Dealer did mine about a month ago. Received a phone call that they were coming to my house, which was a little odd at first because I didn’t even know who I was talking to or if it was legit.
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
2014 MACK CXU613 MID-ROOF SLEEPER (INOPERABLE) (A58214)
2014 MACK CXU613...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A56857)
2019 Caterpillar...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
Club Car Intellitrak Golf Cart (A57453)
Club Car...
