CK2610H WWF rear tire ballst : the job and results
   / CK2610H WWF rear tire ballst : the job and results #1
mangler
Gold Member
Ontario, Canada
Sears G5500, Kioti CK2610
I just added 29 gallons of windshield washer fluid to each rear tire on my CK2610. Initially I thought this was just going to be a small add-on to the 680lbs/box blade I always carry, but it turned out to be more than that.
Actually adding the fluid was not too bad. I used the special valve stem adapter, a 12V bilge pump with PLENTY of flow for the job, a few hose clamps and 3/4" clear vinyl tubing.. I figure a few hours per tire. Mostly sitting there, making sure the 5 gallon bucket remains reasonably full, and stopping the pump and relieving the pressure every few minutes.
The bottom line is it significantly changed the tractor dynamics. Before the WWF ballast I could not stall the tractor on firm ground, even with 4X4 engaged and 680lbs of box blade "ballast". All wheels would eventually spin in low range. With the WWF ballast I can now stall the tractor if I am not careful, which means I am finally putting all the power to the ground. The bottom line is the WWF ballast is quite the value upgrade, especially if you get the WWF on sale. IIRC I paid around $2.20 CAD a gallon. Something I would recommend to all CK2610 owners, unless you have to worry about lawn compression and ruts.
   / CK2610H WWF rear tire ballst : the job and results #2
Thanks for sharing your story. I bought a ballast box to add some traction to my L2501 and perhaps compensate just a bit for the weight of the loader on the front. I have considered filling rear tires as well. I still may.
   / CK2610H WWF rear tire ballst : the job and results #3
My ck2610 doesn’t have the power. I’d be afraid to add anymore weight. Mine has a hard time pulling my grandson in a toboggan.
Unless your grandson is really fat and by toboggan you mean 16 ft harrow, something is wrong with your CK2610...
I'll admit it is not a powerhouse in high gear, but it's not supposed to be. In low gear it has beat up/pushed over every sapling I have pitted against it. In it's weight and power class I find it more than adequate.
   / CK2610H WWF rear tire ballst : the job and results #5
Definitely going to get the dealership to look at it.
   / CK2610H WWF rear tire ballst : the job and results #6
Great idea. In moderate to soft soil, you should be able to spin the tires. Make sure you're in low gear though. High gear is more for transport. I wind up using high gear intermittently, but with how bumpy the ground is and how little "give" the frame of the tractor (and my rear-end) has, it makes for a very rough ride. Low is good for ground engagement. Medium is good for just about everything else.
   / CK2610H WWF rear tire ballst : the job and results #7
Thanks, medium is what I use for finish mowing. It does pretty well until I go up a Slight incline. That痴 when she falls flat. I guess I値l just have to get used to it.
378849 (A51573)
378849 (A51573)
John Deere 9620R Scraper Tractor (A53342)
John Deere 9620R...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2803 (A50460)
2803 (A50460)
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
