Replace loader lift/tilt cylinders with larger ones ?
/ Replace loader lift/tilt cylinders with larger ones ? #1
Arky217
Hartford, AR
Kubota L4200
I have a Kubota L4200 with the Kubota 680 loader.
The lift and tilt cylinders are leaking.
They all are 24" long with a 2" bore.
The best price that I've found for rebuilding the cylinders
is $100 each.
I was looking at the Northern Tools catalog and noticed that
I can get new 2" bore x 24" length cylinders for $160 each.
Also, I noticed that they have 2.5" bore x 24" cylinders for the same price.
I don't know if the cylinder ends and fittings are the same,
but if they are, do you think that the 2.5" cylinders
would over stress the loader too much ?
/ Replace loader lift/tilt cylinders with larger ones ? #2
Well, going from a 2" to a 2.5" cylinder increases the piston area from 3.14sq in to 7.06sq in, so assuming a 2,000 psi system, that would increase the extension force from 6,283# to 14, 137", over double the amount the original cylinder would exert.
If both had the same size rod, say 1", the retraction forces would go from 4,712# to 12,566#, over 2 1/2 times as much.
I would bet that kind of increase would bend or break something pretty quickly.
/ Replace loader lift/tilt cylinders with larger ones ? #4
I get 4.9sq in for a 2.5 diameter piston. So 9800lb lift. And the rod will likely be 1.5 diameter, or perhaps 1.375 diameter. So about 6300lbs down force.
The rods on my JD430 loader are damaged, and i am considering a similar swap. When selecting a suitable cylinder, you also need to consider the end pin type, diameter, and width, stroke, and also the port orientation and type. You may need new hoses to suit the port locations and hose end clocking.
Seal kits are inexpensive and generally a simple DIY repair if the rods are in good condition.
Rod replacement is also an option if the cylinder bore is in hood shape.
Finding a cylinder that meets all the requirements can be a challenge. Be aware that an off the shelf generic cylinder may require some modifications to get it to fit your application. In my case the cyl base end will require additional width, the rod end will need to be narrowed, and the hoses replaced due to phasing of the hose ends would be 90° instead of the current 0°.
/ Replace loader lift/tilt cylinders with larger ones ? #5
To compare extension force of a cylinder we don't deduct rod diameter from the calculation.
I've never seen a FEL that didn't raise by extending a cylinder, or one that couldn't raise high enough to tip a tractor over with an OEM FEL.
How much more counterweight would be needed if doubling lift capacity? What's the load capacity of the front tires?
/ Replace loader lift/tilt cylinders with larger ones ? #6
And the most important: what's the load capacity of the front axle? This is something overlooked a lot mostly because I don't think that manufacturers put this info on US market tractors.
Tractors on the European market have this info displayed on the serial number tag. Will list Max permissible load on front and rear axles.
/ Replace loader lift/tilt cylinders with larger ones ? #7
I paid the same $100 to have my loader curl cylinders rebuilt due to leaking seals after 18 years.
My advice would be to just rebuild your existing cylinders. Simple, exact and easy.
Retrofitting with something that will likely cause damage and future grief is not the way I would go. Now if you had a damaged cylinder that could not be repaired, buying aftermarket might be a reasonable approach, especially after you price OEM cylinders (mine were like $650 plus each)
But it sounds like your cylinders just need new seals like mine did. Happy camper here...
/ Replace loader lift/tilt cylinders with larger ones ? #8
^^^^^This^^^^^ :thumbsup:
/ Replace loader lift/tilt cylinders with larger ones ? #10
is $100 each.
Obviously I don't know you and your background. Having walked this walk....(and being willing to blindly jump into a mechanical project with NO clue what's going on)
I decided to try to rebuild my dipper cylinder on my JCB backhoe. I don't know the diameter but I'm guessing 2 1/2" and it was 107.478% about all I could man handle to carry the darn thing!
These aren't rocket science. Take it off, figure out how to take it apart... you have little to lose if you're willing to buy a new one. I'd take one apart and give it a whirl....the seals have to be available somewhere (if I can find them on ebay for my 1987 machine, they'd have to be available for something more main stream??)
I've since redone my stabilizer cylinders.
I might add... years ago, when I first did my dipper cylinder, I took it to a dealer. They charged me $1,000 to do it and I about passed out on the spot. I STILL (stupidly) paid to have my loader (raising) cylinders redone AND the trunnion (swing) cylinders for the backhoe. When the Dipper cylinder needed it again (after maybe 15 years) my spine stiffened and told myself there was NO way I was going to pay that again unless I had to..... so I dug into it and I think it cost me (forget) maybe $100 in parts.
Heck, when I did my stabilizers, the pins were freezing them on the machine so I was unable to remove the cylinder..... so I did them in place.
/ Replace loader lift/tilt cylinders with larger ones ? #11
I will just add that I priced a seal kit from Kubota and for my cylinders the cost would have been over $60 each per cylinder (delivered) for the seal kits only.
I figured that for the additional $40 per cylinder it was worth it to me to have someone with expertise do the work. Easier too.
The hydraulic shops do not need the seal kits from Kubota. So their cost for seals is probably 10 percent of what mine would have been. They make money there too. I do not have an issue with that at all. If I tried to source all the needed seals/o rings myself, I would lose so much time it would drive me crazy...
/ Replace loader lift/tilt cylinders with larger ones ? #12
There are tractors built today on the market that have loaders that lift more then the front axle is supposed to hold.
/ Replace loader lift/tilt cylinders with larger ones ? #13
I'd stick with factory size.
I'd take them apart. If they are leaking...$10 worth of gland seals at your local hydraulic shop.
Don't even have to remove cylinder from tractor most likely
/ Replace loader lift/tilt cylinders with larger ones ? #14
I've always done mine. Either a cheap kit from the local hydraulic shop or on occasion the factory kit. Not only would I not remove the cylinder I actually think it's easier. You need to remove the rod side but the tractor makes a great vice to hold the cylinder while trying to remove the gland nut. The rod is a good chunk of the weight but it's still a lot lighter than the assembly. For a loader find something like a 55 gallon drum to rest it on, remove all the pressure and have at. It's going to leak oil so be prepared. For something like a loader I'll tape plastic to the hood going under the cylinder to a bucket or something to channel the fluid into it. I even picked up a used 3' pipe wrench for removing the nut. You do one and you'll most likely never bother with paying anyone else to do it.
/ Replace loader lift/tilt cylinders with larger ones ? #15
This ^^ IMO, nuthin' beats cyl base pin for holding steady when muscling the gland nut loose or re-tightening. No slip or scratch/dent cyl body either.
Yes, be sure the loader & bucket are at rest and wobble the stick to relieve pressure.
I like to cap or plug lines I disconnect right away to minimize spills and gravity drips.
When buying items that come with those bits I save 'em in a jar. After a while one can cover a lot of sizes.
/ Replace loader lift/tilt cylinders with larger ones ? #16
Amen you are so correct
/ Replace loader lift/tilt cylinders with larger ones ? #17
Except that a 2.5" diameter cylinder is 4.90 sq in, and the rods are 1.25 diameter. Recalculate the forced based on the correct part sizes.
/ Replace loader lift/tilt cylinders with larger ones ? #18
Correction:
A 2.5" cylinder with a 1.25" rod will exert 9,816# of extension force, 1.56 times a 2" cylinder, and 7,362# of retraction force, also 1.56 times a 2" cylinder.
/ Replace loader lift/tilt cylinders with larger ones ? #19
Once again I will mention the diminished speed that will be a result of increasing the cylinder bore. That is not a potential risk resulting from potential overloading of the structure but a constant reality every time you grab the joystick.
/ Replace loader lift/tilt cylinders with larger ones ? #20
Who operates their loader at full speed anyways?
SKYJACK SJIII3226 ELECTRIC SCISSOR LIFT (A60429)
SKYJACK SJIII3226...
PALLET OF 45" BAR LOCKS (A60432)
PALLET OF 45" BAR...
Zero Turn Mower (A59231)
Zero Turn Mower...
JOHN DEERE 5075E TRACTOR (A60430)
JOHN DEERE 5075E...
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A59230)
2017 Freightliner...
