How much weight do you give CarFax when buying a used auto? (from a dealer)
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #71
And that would be the same problem I'd have unless the car is up in the air.
I cant imagine taking all day to spray rust proofing under a car, according to that video it took less then 2 hours on his SUV. Ether way I dont want to crawl under a car with a spray gun but later on I might consider making a ramp off a bank, high enough to stand under
I should have mentioned......I HAD a lift in my garage!
To do a GOOD job, it is not JUST about "under a car".
Removing headlights, wheels, tail lights, trunk liner, drilling holes in doors and rockers, above windshield, etc.
Just prep time is 2 hours, and re-assembly another 2.
Did you do that every year?
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #73
NO!
I used LPS-3 (has a mil. spec., and is much better than FF, in my opinion)
Inside panels, light cavities etc., one time application only.
Under carriage got touch-up when LPS-3 erosion became obvious.
I spend Winters in Florida now, but I still use LPS-3 on other unpainted steel items that are subject to weather exposure.
It seems to be good for at least 1 year steel exposure protection.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #74
Better than CARFAX, because here you will find much more information: Auto Auction Research Tool | AutoAuctions.io Stop guessing what a vehicle is worth
We show you actual sold prices on used/salvage vehicles so you can find comparables and stop guessing what a vehicle is worth.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #75
Now the next step, make it last, so far this is about the best option I found to slow rust from taking a car/truck before the motor goes. NH oil, a yearly oil base spry on rust deterrent, guess there no such thing as spray it and forget it.......... Stops Rust! New Hampshire Oil Undercoating at Luce's in Union Maine - YouTube
Motorhead Garage, What is Oil Based Rustproofing - YouTube
Other option is move to Texas.............
It’s really hard for me to comprehend what y’all have to put up with regarding rusted out vehicles.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #76
The easiest way to describe it is: Generally, vehicles are rusted out at 10+ years.
Then take lotsa $$$$ .......buy a new one!
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #77
I HAD........... Thats sounds like sad statement right there, I wish I had a lift in my garage just to change the oil, funny how when I was lot younger crawling under a car wasn't so bad, now I dread it. One of my long time car mechanics use to work in his a small shop with no lift, now for the past 8 years he dont know how he ever did a thing on a car years ago.
I think this place neer me just sprays the under side where rust really attacks a car's structure. Right now my 2018 Cherokee is like new underneath so I want to have something done to make it last after its paid for, hopefully it will be the last vehicle I buy........
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #78
I'm with this guy theres just one all cure all, I guess undercoating to really work good, it's just going to have be a yearly maintenance chore or every other year....... LPS-3 Undercoating, 1 Year Review - YouTube
I hand my older Jeep undercoated by someone that used a NAPA product 8 years ago and it is showing signs of neglect.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #79
Fender wells (remove wheels), rocker panels, and lower door seams (internal) are an absolute necessity!
Even so, your Jeep will not maintain Bryant Stoves antique (vehicle) quality.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #80
I think they do the rocker panels and doors but I'll have to ask when I make appointment this week.
I use to work for Bryant Stoves 40 years ago, think they close down 3 years ago right after the original owners past.
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
ford Taurus 2014 (A56859)
ford Taurus 2014...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
set of 4 wheels and tires 205/75R15 (A56435)
set of 4 wheels...
