How much weight do you give CarFax when buying a used auto? (from a dealer)
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #71
And that would be the same problem I'd have unless the car is up in the air.
I cant imagine taking all day to spray rust proofing under a car, according to that video it took less then 2 hours on his SUV. Ether way I dont want to crawl under a car with a spray gun but later on I might consider making a ramp off a bank, high enough to stand under
I should have mentioned......I HAD a lift in my garage!
To do a GOOD job, it is not JUST about "under a car".
Removing headlights, wheels, tail lights, trunk liner, drilling holes in doors and rockers, above windshield, etc.
Just prep time is 2 hours, and re-assembly another 2.
Did you do that every year?
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #73
NO!
I used LPS-3 (has a mil. spec., and is much better than FF, in my opinion)
Inside panels, light cavities etc., one time application only.
Under carriage got touch-up when LPS-3 erosion became obvious.
I spend Winters in Florida now, but I still use LPS-3 on other unpainted steel items that are subject to weather exposure.
It seems to be good for at least 1 year steel exposure protection.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #74
Better than CARFAX, because here you will find much more information: Auto Auction Research Tool | AutoAuctions.io Stop guessing what a vehicle is worth
We show you actual sold prices on used/salvage vehicles so you can find comparables and stop guessing what a vehicle is worth.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #75
Now the next step, make it last, so far this is about the best option I found to slow rust from taking a car/truck before the motor goes. NH oil, a yearly oil base spry on rust deterrent, guess there no such thing as spray it and forget it.......... Stops Rust! New Hampshire Oil Undercoating at Luce's in Union Maine - YouTube
Motorhead Garage, What is Oil Based Rustproofing - YouTube
Other option is move to Texas.............
It’s really hard for me to comprehend what y’all have to put up with regarding rusted out vehicles.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #76
The easiest way to describe it is: Generally, vehicles are rusted out at 10+ years.
Then take lotsa $$$$ .......buy a new one!
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #77
I HAD........... Thats sounds like sad statement right there, I wish I had a lift in my garage just to change the oil, funny how when I was lot younger crawling under a car wasn't so bad, now I dread it. One of my long time car mechanics use to work in his a small shop with no lift, now for the past 8 years he dont know how he ever did a thing on a car years ago.
I think this place neer me just sprays the under side where rust really attacks a car's structure. Right now my 2018 Cherokee is like new underneath so I want to have something done to make it last after its paid for, hopefully it will be the last vehicle I buy........
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #78
I'm with this guy theres just one all cure all, I guess undercoating to really work good, it's just going to have be a yearly maintenance chore or every other year....... LPS-3 Undercoating, 1 Year Review - YouTube
I hand my older Jeep undercoated by someone that used a NAPA product 8 years ago and it is showing signs of neglect.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #79
Fender wells (remove wheels), rocker panels, and lower door seams (internal) are an absolute necessity!
Even so, your Jeep will not maintain Bryant Stoves antique (vehicle) quality.
   / How much weight do you give CarFax when buying a used auto? (from a dealer) #80
I think they do the rocker panels and doors but I'll have to ask when I make appointment this week.
I use to work for Bryant Stoves 40 years ago, think they close down 3 years ago right after the original owners past.
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2016 Husqvarna YTA18542 42in Riding Mower (A56859)
2016 Husqvarna...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56435)
2017 John Deere...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A55973)
2022 Power Screen...
2008 TEREX TRAILER LIGHT TOWER (A58214)
2008 TEREX TRAILER...
