Better tie-down system for truck bed
   / Better tie-down system for truck bed #1
BigBlue1
Elite Member
Middle MN
JD: 2520 & x758
I often find the 4 U-bolts in my truck bed to be inadequate for strapping things down that I carry. They are so close to the front and back that going straight across often allows very little coverage of the cargo. Going in an X pattern can work but that can be difficult for odd shaped stuff.
I'd like to have attachment points along the full sides of the bed. Down low is obviously good, but sometimes even at the height of the top of the wheel well would be fine for taller cargo. Anyone know of a good add-on system that isn't going to be always in the way on the bed surface? Something like a rail system mounted right over the wheel wells that would be solid enough to allow 2 or 3 attachment points per side would seem to be the best idea, though I have no idea how it would attach to the bed sides or if they are structurally sound for that.
ETA: At this point I have some good ideas on the actual types of cargo rails so we're good there. If anyone has ideas on how to attach a rail system to the sidewall of the truck bed, preferably on a 4th gen Ram, I would appreciate that still.
   / Better tie-down system for truck bed #2
cargo rails both sides of the bed. metal bed rails with added tie down points. webbing net to strap down to the factory loops.
   / Better tie-down system for truck bed #3
E track system in my F150
Etrack hooks can be placed anywhere along the length of the track for use with ropes or ratchet straps.
Is there a system you know of like you describe? Looking for pointers. I can certainly do Google searches but I'm looking for recommendations on good stuff that isn't gimmicky.
   / Better tie-down system for truck bed #6
SS 1/4-20 cap screws, fender washers, NYLOCKS and silicone seal.
You can get behind the bed sides to put washers and nuts on?
OK, so those E tracks look good but based on looking around at them I found a couple others that seem like just what I'm looking for. Either Mopar's own Utility Rail System or the Core Uni Trax or Maxx Trax system.
OEM Mopar Bed Utility Rails, 5'7" Conventional Bed For 2?19-2?21 Ram 15?? - Part# 82215285AB | Suburban Auto Parts
https://www.coretiedowns.com/products/tie-down-solutions/
The Mopar system is for 5th gen Rams, so I'm not sure if they can be used on a 4th gen. I guess I'll have to figure out how to fasten either of those to the bed sides of my 2017 Ram 2500. Looks like nutserts are an option for blind fastening but I'm not sure the bed side walls would be structurally sound enough for this.
Rob
   / Better tie-down system for truck bed #9
I ran a small chain starting at the driver rear and thru every tie down and ended at the passenger side rear. Essentially one large U shape. Gives me multiple points to hook my tie down straps.
   / Better tie-down system for truck bed #10
I took the liner off to bolt from the backside.
There are probably many systems available for pickups.
The Etrack i had was the same that we used on all our semi van trailers therefore there all attachments available are heavy duty. (Including load lock bars as shown in at least one of my photos. )
JCT 72" Skid Steer Rotary Brush Cutter, Asset# 68 (A59076)
JCT 72" Skid Steer...
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
Bucket (A55973)
Bucket (A55973)
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
Dewalt D28493 7/9" Angle Grinder/Sander (A59076)
Dewalt D28493 7/9"...
Mini Skid-Steer Hydraulic Skeleton Grapple Bucket (New/Unused) (A59225)
Mini Skid-Steer...
