GC2410 Hood
   / GC2410 Hood #1
WANNABE1
NH
Massey Ferguson GC2410
Hi all, I lifted my hood the other day to get the battery charger off and when I tried to lower the hood to close it it came off at the bottom where it was hinged, was wondering if it is welded on or if it is made to be removable but either way I could use some guidance in how to reattach it.
Thanks all
Chris
   / GC2410 Hood #2
For what it's worth, my 2310's hood is bolted on, both on the underside of the hood and at the hinge points on the frame, using a U-shaped tubular sub-frame.
   / GC2410 Hood
Thank you IrvingJ
That is what I was thinking too but then thought that perhaps they made these to be easily removed for easier access if needed.
   / GC2410 Hood #4
Here's how mine's bolted -- 4 bolts (I should say, nuts -- they're on studs that protrude from the hood) on the under-hood brackets, two hinge bolts down by the black grille. They probably use an elastic stop-nut on those hinges so it can still move but the nuts stay put; sounds like one of yours may have come off.
Where you at in NH?
   / GC2410 Hood #5
Good question-I will have to take a look a bit later.
   / GC2410 Hood #6
2010 GC2400 hood
2 bolts in from side separate hood from tractor 2 bolts from underside sep hinge.
attached is page 37 of service manual (eng removal section) showing removing 2 bolts for hood.
would have attached actual pdf page but could not, can not get graphics any better sorry
   / GC2410 Hood
2010 GC2400 hood
Thank you, I think this is the set up I have, so I am thinking my bolts came off or snapped, now that I know a little more of what I am dealing with thanks to your great photos I can proceed in repairing it.
   / GC2410 Hood
Where you at in NH?
View attachment 682891 View attachment 682892
Yours set up is different than mine, the comment below with pictures is what mine looks like. Thank you for taking the time to show me all that
I am in Mason NH, Home of the famous Parkers Maple Barn.
   / GC2410 Hood #9
prob the differences between gc2300 and gc2400 series.
don't have a 1700 series in yard right now but think it uses setup similar to the 2400 pics I posted but don't hold me to that.
edit:
if hinge is broke for gc2400 hinge part number is 6254355M2
   / GC2410 Hood
edit:
Thanks again, I will have take a better look at the hood hinge and check it out, thanks to you and others I now have an idea what I am dealing with.
2019 GALYEAN...
BRADCO HP600 COLD PLANER (A52707)
BRADCO HP600 COLD...
2015 Ford F-550 Altec AT40M 40ft. Bucket Truck (A55852)
2015 Ford F-550...
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2021 Club Car Carryall 500 Electric Utility Cart (A55851)
2021 Club Car...
