Mini/midi ex land clearing on slope
   / Mini/midi ex land clearing on slope
Sounds like a job for manual labor then. Maybe a crew of 15 people with saws and follow up with goats?:goat:
That could work. We discussed it. In fact, they are doin that now, with 5 men and saws. Progress is too slow.
But if you were actually on site, like me, not 1000 miles away like you, youd see a small track machine is what will work. :thumbsup:
   / Mini/midi ex land clearing on slope #42
I like the idea of the mid sized excavator with a forestry mulching head,working a semi circle would reduce the travel time com pare to mowing/mulching time.
From what I have seen around here the final job by a mulcher unit is much neater and cleaner then the same job by a brush hog.
The main problem I have seen with the mulchers is when they catch a dang rock it can tear up teeth awful fast.
A mulcher or brush hog on a tracked skidsteer has to drive every were it cuts where as a boom mounted unit can reach out aways for steep banks or draws.
   / Mini/midi ex land clearing on slope #43
No, he doesnt. You are out of your league.
No more so than you are if you don't know which piece of equipment to use, or... how to even do the job. Perhaps honesty with the potential client is in order; tell them what you are telling us. :confused3:
   / Mini/midi ex land clearing on slope #44
BTW...I agreed with another poster (post 21) that a CTL with a mulcher head is how that job is done here. :thumbsup: Have fun!
This was my original thought and title for the thread. Nobody will rent them in my area, so I’m limited to rubber track skid machine with mulcher or brush cutter.
I am looking for someone in my area who owns a mini/midi with mulcher head I can supervise for them. Moved on from that to tracked skiddy.
My original question shows I know EXACTLY which piece of equipment to use, but its not rentable. Its not like when you moved out of the city and bought your first piece of land and had no idea what to do and I helped you. You are projecting, again.
I know exactly how to do and handle the job. Done more land clearing that you have ever dreamed of.
You are out of your league lil fella.
   / Mini/midi ex land clearing on slope #47
Are you joking? :laughing:
I have a Deere CX-15. We are well past the capability of a garden tractor with a 5 light duty cutter. :laughing:
Im clearing 30 foot tall autumn olive and sweet gum with 4-5 inch bases. Your residential duty field mower would be destroyed in an hour. Your tractor would be stuck before that. I can稚 even get a 150HP farm tractor with 4wd and AG tires in there. :laughing:
You told us you were going around the trees, not mulching through them. If your going to clean up trees then what I showed is definatly not going to work.
You need to get off your high horse for a bit instead of insulting all the people who are honestly trying to give you ideas.
Did you read the first post of the thread?
Here it is, just for review. This is the first sentence in post #1:
Customer wants 12 acres of autumn olive, vines and small sweet gum cleared.
If you did, youd see why your suggestion is irrelevant. I will be clearing small trees (30 feet tall and 3-4” diameter and working in between large trees). Your machine is nice, but not designed to do that.
I have taken the sensible comments and ideas made by others and Im using them! I get you want to help, but the mere suggestion of using a light duty field cutting machine shows more of a lack of understanding on your part.
Hope you understand, no offense intended and appreciate your contribution-I just cant do it with what you are suggesting or I would use one of my tractors and CX-15s. They can cut stuff up to 3-4”, but the slope it too steep :thumbsup:
   / Mini/midi ex land clearing on slope #49
On the subject of mini excavators and hills it seems like not putting stabilizers on them like the larger wheeled excavators have is a missed opportunity. After purchasing a mini I very quickly missed the ability to level itself on most hills like a backhoe can. For that matter not offering a mini with wheels seems dumb. More times than not being able to move faster than 2 mph would be better than the flotation offered by tracks. IMG_9599.JPG
On the subject of mini excavators and hills it seems like not putting stabilizers on them like the larger wheeled excavators have is a missed opportunity. After purchasing a mini I very quickly missed the ability to level itself on most hills like a backhoe can. For that matter not offering a mini with wheels seems dumb. More times than not being able to move faster than 2 mph would be better than the flotation offered by tracks. View attachment 684254
Good observation. Blade is only stabilizer and not all that wide. All I could do is face uphill and work, but not sideways on the steep slopes.
The railroad guys in my little town have a wheeled loader on rail gear they use for clearing ROW brush & branches.
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2017 Ford F-250 Enclosed Service Truck (A55788)
2017 Ford F-250...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
