Porchfan
- Joined
- May 11, 2013
- Messages
- 125
- Location
- Oak Ridge, NC
- Tractor
- 2013 Kubota B2650 HSD, 2020 BX2380, JD LX-277 lawn tractor 2000
So I have two tractors, a B2650 and a Bx2380. Both are HST and are used regularly in and out of 4 wheel drive. I have always had a hard time getting the BX out of 4x4 mode until yesterday. Never with the B2650. Yesterday, I was really struggling getting the BX out of 4x4. Not sure why this time was really bad. What I would usually do is move the tractor back and forth until I could jam the lever out of 4x4. Sometimes it would
make a banging noise when I succeeded. Other times
It would be a little tough and no noise. I’ve tried reverse, neutral, the brake, steering wheel
Positions, being on a hill going down, or go up and still no consensus on the best way to do this.
I had just got on my concrete driveway and that usually is always worse. Yesterday it was just stuck big time and so was I.
Sitting there for about 10 minutes it dawned on me that the hydrostatic torque on the front wheels could be the reason why it is so hard to move out of 4x4. I then thought if I could lift the wheels up, that torque would reduce enough or go away and I’d be able to get it out of 4x4.
So - I tried it using the FEL and bucket and BINGO! After lifting the front wheels off the ground, the lever to move out of 4x4 was never easier to move. I could move it with my bad pinky. Ok. So now I have a way if I have the FEL on the tractor. Problem is I use this tractor to mow the yard and rarely have the FEL attached when mowing. I also have to put it in 4x4 in a couple spots when mowing in the yard so the rear wheel don’t spin and tear the yard up.
Ugh.
Curious if any of you all have had this issue and have done what I did or something else that gets you out of 4x4? What’s the best way to get out of 4x4 when you don’t have the FEL on? Also interested in understanding why I’ve never had an issue with my B2650 going to 2 wheel from 4 wheel drive? Maybe I need to read the manual? I’ve only had the Bx for 5 months. Haha. Fire away folks.
Thanks -
Ugh.
Thanks -
