HOT WATER MYSTERY
   / HOT WATER MYSTERY #11
Go around your house and close all the shut offs on each of your fixtures in kitchen, baths, laundry, sinks, etc... and then try them one at a time. That could isolate the problem fairly simply, just takes time.
   / HOT WATER MYSTERY #13
Just guessing on my part but don't water heaters have an internal tube on the inlet (cold) side down to the bottom of the tank and the hot water is drawn off the top of the tank ? I think I've heard of these tubes either rotting away or falling off inside the tank and causing a similar situation but I'm getting older and my mind isn't quite as sharp as it used to be. Anyone else know what I'm talking about ?
It is called the dip tube.
Troubleshoot and replace water heater dip tubes
   / HOT WATER MYSTERY #14
Mixing valve open or gone bad maybe.
   / HOT WATER MYSTERY #16
The lower heating element is shot. the upper element is only a maintainer element. maybe the lower element reset button popped. try resetting button.
   / HOT WATER MYSTERY
Wow!
3 really GOOD ideas!
1st.....I will try isolating each single point faucet, though the shower one may be difficult.
2nd......I will try to remove and inspect the dip tube.
3rd......I will replace the toilet mix valve.
Thanks guys, for three GREAT troubleshooting suggestions.
   / HOT WATER MYSTERY #18
Is it possible that a 3 point cartridge could fail internally to allow this to happen?
Which cartridge.....I have 3 of them.
If one cartridge failed internally, would it affect the supply to the hot side of the other two?
Could a failed toilet mix valve be the problem?
This is all not good!
It's none of the three valves you can control manually. If it were one of them you couldn't get straight cold from the failed one. It's a washing machine, dishwasher or other fixture where the water can mix if something fails. Cut one or both supplies to each one at a time and test.
Lower element failure should give you more hot water than you are reporting. A dip tube failure is a real possibility.
   / HOT WATER MYSTERY
Removed and inspected both elements at the beginning of this diagnostic process.
Both elements have normal continuity.
When I drained the heater to remove the elements, the water was plenty hot!
   / HOT WATER MYSTERY
Considering the symptoms......hot water initially, but quickly only warm water, dip tube failure does seem to make the most sense.
I will check it out......my second option.
Thanks!
2016 HAMM HD+ 120I DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
KUHN GMD-310-HD LOT IDENTIFIER 38 (A53084)
KUHN GMD-310-HD...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2016 TAKEUCHI TB290 EXCAVATOR (A51246)
2016 TAKEUCHI...
