HOT WATER MYSTERY
   / HOT WATER MYSTERY #21
Wow!
3 really GOOD ideas!
1st.....I will try isolating each single point faucet, though the shower one may be difficult.
2nd......I will try to remove and inspect the dip tube.
3rd......I will replace the toilet mix valve.
Thanks guys, for three GREAT troubleshooting suggestions.
How old is your water heater ?
I just changed my electric water heater out last year (was 25 years old) a long with the well pressure tank just so I might eliminate future issues with the older equipment.
Good luck finding your problem.
KC
   / HOT WATER MYSTERY #22
Wow!
Putting a hand on the cold water supply pipe to the shower while/just after running another faucet will be just as good.
   / HOT WATER MYSTERY
Thinking some more about the failed dip tube idea.
A failed dip tube would not account for cold water coming from both hot and cold sides of each of the 3 single point faucets,....... while the water heater is completely isolated , with both 1/4 turn valves at the top of the heater shut off.
   / HOT WATER MYSTERY
GOT IT !!!!
The cold water is apparently back feeding through the hot/cold washing machine wall mounted supply valve!
WHOOPIE !!!
   / HOT WATER MYSTERY #25
GOT IT !!!!
The cold water is apparently back feeding through the hot/cold washing machine supply valve!
WHOPPIE !!!
If you nailed it, not too bad to fix, either!
   / HOT WATER MYSTERY #26
GOT IT !!!!
WHOOPIE !!!
Wow, a thread with a resolution! Thanks for posting it.
   / HOT WATER MYSTERY
The "fix" is/will be the conclusion of a very interesting/frustrating scenario.
That washer wall mount valve is OLD, and dripped for a while each year, when I turn the system back on after it having been asleep (drained) for Winter (Covid changed this Winter for me).
A few weeks ago I decided it was time to change that valve (the new valve had been sitting in a box for 2 years), and finally solve the dripping issue.
Changing the valve was going to be a project, involving moving stuff, removing the old valve, and replacing with new, all in a rather difficult spot.
Ah Ha, I thought, these valves appear to be identical.
I'll just take the guts out of this new one, and put them in the old one.
These are both high quality brass valves.
The drip was fixed, and all was well......until something went wrong....like NOW!
I did save the new valve body, so just in case, I could put the parts back in, and replace the entire old valve assy. with that.
Ain't gonna happen!
I am 80 years old......gonna buy a complete new valve assembly tomorrow.
When am I gonna get the urge to put it in?
I dunno!
Hot water works normally..... while the valve is off,...... and it only needs to be on for laundry!
2 more years maybe?
   / HOT WATER MYSTERY #30
The "fix" is/will be the conclusion of an an interesting/frustrating scenario.
That washer wall mount valve is OLD, and drips for a while, when I turn the system back on each year after it being asleep (drained) for Winter (Covid changed this Winter for me).
I did save the new valve body, so just in case, I could put the parts back in, and replace the old valve assy. with that.
Ain't gonna happen!
I dunno!
2 more years maybe?
Ha!!! You sound like me.
My wife, however, would require the fox be made ASAP. Otherwise, she’d Salk a plumber.
MoKelly
ROADTEC RP-190E-3043 ASPHALT PAVER (A51246)
ROADTEC...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
Adams 5 T Spreader (A53472)
Adams 5 T Spreader...
2012 BMW 328i Coupe (A51694)
2012 BMW 328i...
