HOT WATER MYSTERY
   / HOT WATER MYSTERY #42
Learned something new today. I'd never heard of a toilet mixing valve. Must be a northern thing? Though my dad did run hot to a toilet once by mistake. He never lived it down. :rolleyes:
   / HOT WATER MYSTERY
A toilet mixing valve works great to prevent toilet tank sweating.
Toilets sweat, both North, and South.
I finally figured it out that it had failed, with the help of so many helpful TBN friends.
Amazon..... "Anti sweat toilet valve"...$20.06.
I'll get one tomorrow, at my local plumbing supply store.
They are an often installed item around here, but failure is not common.
This one was 40+ years old though, so guess it was time.
   / HOT WATER MYSTERY #44
   / HOT WATER MYSTERY
That could get spendy after a number of years....good thing you found it.
If that were to continue for a long time.....and I knew about it...
I could simply wear dirty clothes.
I once wore the same coveralls for 9 hot and sweaty days.
The Navy made me do it!
   / HOT WATER MYSTERY #46
If you are on well water the tank could be full of sand or some muddy material.
but check the cold inlet pipe inside of the tank to carry water to the bottom of the tank.
if good then flush the tank with a drain valve. if clear almost has to be a cold water inlet pipe.
   / HOT WATER MYSTERY #47
I once heard a story about a new recruit who was in a long line outside and had to pee. He was afraid to get out of line and even to ask permission. When he couldn't hold it any longer he let it run down his pants leg. For some reason or other he didn't get to change clothes for several days.
   / HOT WATER MYSTERY #48
Oh, you're in Florida. I was thinking northerners must use them to prevent the tank freezing. With all the SC humidity it's a wonder I haven't heard of them.
   / HOT WATER MYSTERY
I was in my first 9 days at the US Naval School of Preflight.
We had to surrender all out personal clothes upon check-in, and were issued a set of coveralls to wear, with only underwear beneath.
Spent 9 full days running, and drilling, in hot Florida in that set of coveralls, without them ever being washed.
It was nicknamed a "poopy suit", and after several days it could almost stand against the wall by itself.
   / HOT WATER MYSTERY #50
Sweating toilet? Now that’s something I never heard of. Except me sweating carrying in a Kohler 1 piece toilet.
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
HUSKEY 5/16" X 50' CABLE DRUM AUGER MACHINE (A51248)
HUSKEY 5/16" X 50'...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
(4) 64" X 40" ALUMINUM POP-UP SIDE WINDOWS (A51248)
(4) 64" X 40"...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A53426)
2005 INTERNATIONAL...
