8n 3 point won't lift
   / 8n 3 point won't lift
   / 8n 3 point won't lift #12
Yes you definitely need to complete remove the stay bars ! The stay bars are used to keep the drawbar from swinging or raising or lowering, did the drawbar come with the tractor ? Maybe that’s what the barrel is sitting on ?
That makes sense yes their is a draw bar its home made and welded to the barrel. I'll have to lift the barrel off with my cherry picker this weekend. I feel dumb.
   / 8n 3 point won't lift #14
Do not feel dumb it is just another learning experience !
   / 8n 3 point won't lift #16
With that much weight and the pump is probably being on the worn side but when I had an 8N it would bend the stabars like pretzels when I would forget and try to use the lift with them on. In fact I did it again last year using my 850. Between myself and my SIL we now just keep an extra set on hand for when the hand works before engaging the brain.
Ford at one time had a chain you were to hang over the lift handle when you had the bars installed as a reminder not to use the lift.
It had a lock out on the handle. I can see the rods wanting to bend they flex like it wanted to lift. Theor is allot of weight on it once this snows gone ill pull the barrel and put my woods mower on that's all it will need to lift and maybe a 3pt two row plow and disc. I want to make a better food plot this year.
Loader with IH Brackets (A50515)
Loader with IH...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
1 guard rail (A49346)
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
