8n 3 point won't lift
   / 8n 3 point won't lift
   / 8n 3 point won't lift #12
Yes you definitely need to complete remove the stay bars ! The stay bars are used to keep the drawbar from swinging or raising or lowering, did the drawbar come with the tractor ? Maybe that’s what the barrel is sitting on ?
That makes sense yes their is a draw bar its home made and welded to the barrel. I'll have to lift the barrel off with my cherry picker this weekend. I feel dumb.
   / 8n 3 point won't lift #14
Do not feel dumb it is just another learning experience !
   / 8n 3 point won't lift #16
With that much weight and the pump is probably being on the worn side but when I had an 8N it would bend the stabars like pretzels when I would forget and try to use the lift with them on. In fact I did it again last year using my 850. Between myself and my SIL we now just keep an extra set on hand for when the hand works before engaging the brain.
Ford at one time had a chain you were to hang over the lift handle when you had the bars installed as a reminder not to use the lift.
It had a lock out on the handle. I can see the rods wanting to bend they flex like it wanted to lift. Theor is allot of weight on it once this snows gone ill pull the barrel and put my woods mower on that's all it will need to lift and maybe a 3pt two row plow and disc. I want to make a better food plot this year.
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
Bush Hog R0-720 Roll Over Box Blade (A51691)
Bush Hog R0-720...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51691)
2013 Mitsubishi...
