Dripping a Frost Free Hydrant
   / Dripping a Frost Free Hydrant #11
Sorry, it's in the winter position and I didn't want to mess with it to take a picture that means something.
No it doesn't leak, but you have to get the position right. I drilled the hole and then installed a collar or bushing to get it just right. It's just now, I realized why the bushing was in there. It might have been impossible to drill the hole in the right spot the first time, but you can play with the length of the bushing.
I don't like to waste precious groundwater every time I operate the hydrant. But my hydrant is atop an underground pump house and the discharge hose from the hydrant feeds into a five gallon pail that I would prefer not overflow.
   / Dripping a Frost Free Hydrant #13
To drain fully and reliably disconnect any hose from the hydrant.
I use a garden hose "Y" with shut offs connected directly to the hydrant.
After closing the hydrant handle, I will shut off the side of the Y with the water hose attached (so the weird tasting water inside the hose stays in the hose), and then I will open the unused side of the Y (so the water in the hydrant can drain out/down).
KC
https://www.acehardware.com/departm...VFRDnCh3CtwxKEAQYDSABEgKkJfD_BwE&gclsrc=aw.ds
   / Dripping a Frost Free Hydrant #14
   / Dripping a Frost Free Hydrant #15
KC
I've got one of those. I only use it in the summer and the little valve handles are a pain in the summer. I think they would be even stiffer at 0 degrees F. Wouldn't you still need to drain the hose to avoid freezing.
   / Dripping a Frost Free Hydrant #16
Seems so.
In the summer, there’s no need to drain (let air in) the hydrant pipe. Any water that might be siphoned back into the hydrant from the hose is just going to drain into the ground or get flushed out as soon as hydrant is reopened. If the hose has a spray nozzle on the other end, no water will be siphoned back into the hydrant unless there’s leaks.
Leaving the hose’s “T” valve open when you open the “air” side valve not only allows the hydrant to drain, but allows the hose to drain out its far end too (also ideal in winter).
   / Dripping a Frost Free Hydrant #17
All our external faucets on the house have an anti-siphon fitting, When you turn them off with a hose attached the pressure drops and eventually it opens and releases the water.
I wonder if you could just put one on the frost proof hydrants and then it should automatically drain the hydrant. Or does it just let the pressurized water in the hose drain but keeps a seal on the source side?
https://www.lowes.com/pd/AMERICAN-V...exqBeJ6pHM1DVaUSBCEaAgPTEALw_wcB&gclsrc=aw.ds
   / Dripping a Frost Free Hydrant #18
Be sure to take hose off. Bet you never heard that before didjee? :wizard:
   / Dripping a Frost Free Hydrant #19
(Edit: Device breaks vacuum, allows air in, hose and pipe to drain. Do or...)Don’t use on a hydrant. This is a backflow preventer. An anti-siphon, one way valve, call it whatever. Hydrants NEED to backflow (water and air) so that the hydrant’s standpipe coming out of the ground can drain itself of water down to a point below the frost line. If there’s water in the standpipe above the frost point, it will freeze in the the standpipe solid. Then your $#@&*ed. This is why you must remove hoses from hydrant (or open a bleeder valve like MF Red’s) when you turn hydrant off.
The reason you want an anti-siphon backflow preventer on your houses external faucet is so you don’t siphon the water in your garden hose that’s been laying in the sun back into your house and drinking water.
Perhaps others can explain how this could occur when you leave an external faucet on that is connected to a hose with a (shut off) nozzle at is outlet. Perhaps if your drinking fountain is significantly lower than the garden hose? (Or your neighbor’s drinking fountain? .... but backflow preventer at house supply should prevent this?) Or if you turn of city water supply, then someone opens a low drinking fountain?
   / Dripping a Frost Free Hydrant #20
Yeah, was aware of it's purpose. What I don't know is if it eventually will let the source side vent once all the hose side pressure is gone though.
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
