Cat 6 Wiring and Electrical Wiring
   / Cat 6 Wiring and Electrical Wiring #61
150ft is no problem, like others have said keep it under 300ft
Dig a small trench and put it in there. Conduit or not, either way, it will be fine
Ive had a 150ft run of cat5e buried directly in the ground (no conduit) from my house to the garage forever... only had one issue since 1 only buried it 4-5 under the surface... Someone that was helping us with some yard work picked the wrong spot to stab his shovel into the ground when he was done working. He could have picked any other spot, lol. So I re-ran a new cat5e again, still no conduit, and its been fine ever since.
In hindsight, anything to protect the ethernet cable from shovels or things of that nature would be ideal but not necessarily needed
Maybe the 3rd time I run the cable I might take the extra time to install some conduit (pvc, metal, anything)
Rated for direct bury or just plain everyday CAT5? I suspect we overthink many such things.
   / Cat 6 Wiring and Electrical Wiring #62
I used to use direct burial and in some places it works just fine. Neighbor did direct burial and the gophers cut it so he placed it in conduit.
And of course there are ants that get into some of the electrical stuff (mostly connectors from my experience)
   / Cat 6 Wiring and Electrical Wiring #63
Plain everyday cat5e
I prefer the “cables to go” brand, model 56011 (1000ft) for cat5e or model 56018 (1000ft) for cat6
It’s pretty good quality cable for the money, zero complaints
   / Cat 6 Wiring and Electrical Wiring #64
I prefer the 田ables to go brand, model 56011 (1000ft) for cat5e or model 56018 (1000ft) for cat6
It痴 pretty good quality cable for the money, zero complaints
I've heard good thing about them. I've gotten a bit of stuff from fs.com too.
Just make sure you get the correct ends for crimping. Riser is typically solid copper.
   / Cat 6 Wiring and Electrical Wiring #65
I bought mine from Platt Electric, a PNW regional jobber. They will cut cable to length.
   / Cat 6 Wiring and Electrical Wiring #66
Dryer fabric softener sheets will keep ants out of an enclosure. Ants are a common problem in rural installations.
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
2015 TAKEUCHI TL10 SKID STEER (A52705)
2015 TAKEUCHI TL10...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52705)
2015 JOHN DEERE...
