Buying New | KX-033 vs. KX-040 | Compact Excavator
   / Buying New | KX-033 vs. KX-040 | Compact Excavator #11
I have a new KX33 that I like a lot with thumb and 6 way blade
   / Buying New | KX-033 vs. KX-040 | Compact Excavator #13
   / Buying New | KX-033 vs. KX-040 | Compact Excavator #14
I have it on my KX 33. It comes with cab and 6 way blade and also got the option for a Thumb. It is a very handy machine and just the perfect size for me
Wow! You should upload a video for us. I've never seen a KX-033 with a 6-way blade.
   / Buying New | KX-033 vs. KX-040 | Compact Excavator #16
I bought a kx040-4 a few months ago. I sat on the 33. It’s a little smaller from what I remember. The thumb is great, my first after having many digging machines through the years. I do wish the thumb was wider for small debris pickup. The heater will absolutely run you out of the machine. I have not got to use the ac yet but I’m hoping its as good as the heat. I did upgrade my air filtration because the factory set up is crap. And recently made some spacers to widen the foot pedals. Other than that I cant find anything bad about it. I do know the new 5 series are coming out with a refreshed interior. Oh,I have the angle blade.
   / Buying New | KX-033 vs. KX-040 | Compact Excavator #17
I have the kx121 with the 4 way blade. You know these things aren't dozers. You can do a little with them but you run out of umph when trying to do much dozing. I thought about the 6 way and kinda glad I didn't pay extra for it. Thumb and quick tach buckets a must. Go with the 40 the 4k lifting is worth it. Get a 14k dump trailer to haul it around. Works good for me. Good luck.
   / Buying New | KX-033 vs. KX-040 | Compact Excavator #18
I don’t know why they didn’t make a tilt blade the standard second option vs an a angle blade. The angle blade is close to worthless. I think a tilt blade would prove fairly useful. And yes a mini x isn’t a dozer. The blade is more pushing loose dirt vs carving out roads and such.
I've decided on the KX-040 ... now the waiting begins ..... for both the machine and for the snow to melt. I've purchased a used single axle Berkelmans "2 ton Big 'Lil Dumper" hydraulic dump trailer to tow behind my Kubota BX .... I just put new idler hub kits on both sides. Once I get rear remotes installed on the tractor I will officially be ready for the excavator!
- James
   / Buying New | KX-033 vs. KX-040 | Compact Excavator #20
- James
I’d weld a hitch on the mini blade so you don’t have to keep swapping machines.
1840 (A51248)
1840 (A51248)
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
Golf Cart (A55853)
Golf Cart (A55853)
flooring (A55758)
flooring (A55758)
