Lots of black smoke, I'm guessing turbo, am I right?
   / Lots of black smoke, I'm guessing turbo, am I right? #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
I recently bought a bigger excavator at auction and I'm seeing lots of black smoke out the exhaust when I'm under load. I'm thinking it's probably the turbo but, curious if you guys have other ideas? It still has decent power, I'm able to dig with it and yank trees out of the ground, it doesn't really bog down, just smokes. At idle, it sounds a little like it's got a hot cam in it also, kind of lopes. Any thoughts?
   / Lots of black smoke, I'm guessing turbo, am I right? #2
I'll say it's bigger ! Perfect size homeowner machine! Is it using any oil ? Check your air filters if you haven't, have seen that issue with plugged filters. How many hours on her ? I would think a bad turbo would provide other issues !
   / Lots of black smoke, I'm guessing turbo, am I right? #3
Black smoke is usually too much fuel or not enough air. I would check the air filter first.
   / Lots of black smoke, I'm guessing turbo, am I right? #4
Also could be that someone turned the fuel up on the injector pump. My dad was bad about that on the farm tractors we had. Those things would smoke like a freight train in a hard pull. They did it day in and day out without an issue.
   / Lots of black smoke, I'm guessing turbo, am I right? #5
It could be a stuck open injector as well...
If it allows, do a contribution test.
I removed the air filter, it definitely needs to be cleaned or replaced but, even without it I got the smoke. I could hear the turbo spooling nicely with the air filter out though, doesn't mean it's not bad. I haven't pulled the intake off to check it for play yet.
Turned up fuel is definitely a possibility, this machine started life with an EGR and DPF so, I shouldn't be seeing any smoke, no matter what. I'm guessing that someone coded them out and cored the DPF, which is fine with me I don't think that stuff belongs on construction equipment anyway.
I don't have the Volvo computer to run a contribution test. An injector makes sense also.
I did check for blow by, BTW, I don't see any.
I've got someone scheduled to come out Friday, an independent tech, not a Volvo guy. Hopefully he'll have a way to test injectors without pulling them. I'd like to get this figured out before he gets here, if it is just the turbo, I'll probably cancel him and do it myself.
   / Lots of black smoke, I'm guessing turbo, am I right? #7
Could be Injector issues. Check your clamps on your turbo plumbing, too. Overfueled or under aired
   / Lots of black smoke, I'm guessing turbo, am I right? #8
Might be a bad or misused tune then?
   / Lots of black smoke, I'm guessing turbo, am I right? #9
Pretty easy to see if DPF is cored (as long as it's easily accessible)
   / Lots of black smoke, I'm guessing turbo, am I right? #10
Son of a bee...that's an excavator!
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55314)
2023 Kubota...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
Kubota LA1055 (A53314)
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
