Jinma / JW03 Backhoe Hydraulic pressure release valve
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #11
With a screwdriver, remove the adjusting screw being careful to count the number of turns (write it down).
Ooops. I guess I'll be getting a pressure gauge, and installing a port for it. :)
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #12
Good call. And be sure to use schedule 80 pipe or hydraulic fittings.
Thanks Bob
Anybody used this one ?- is 11 GPH ok for this application. Do you need to replace hose for this application ?
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #14
Thanks Bob
Eleven gallons per minute is fine for this application (I believe your tractor system is 7 gpm).
Yes, you will have to replace hose assemblies or hose end fittings with reusable fittings (this is what I had to do), or take to a hydraulic shop. One end of the hose has the metric ORFS fitting, the other end of the hoses for the new valve need to be:
  • A & B Work Ports: #8 SAE O-Ring (3/4”-16) Thread
  • Inlet Port: #10 SAE O-Ring (7/8”-14) Thread
  • Outlet Port: #10 SAE O-Ring (7/8”-14) Thread
OK Bob great info thanks so much- one more thing - Do you know what size the ORFS fittings are on the current hose at valve stack now. [ I presume both ends are the same ] I will see if someone makes a adapter from that to the 8 and 10 SAE ports.?
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #16
IIRC, the working hoses are 14mm (~1/2"), and the inlet/outlet hoses are 18mm (~3/4").
Tommy at Affordable Tractor used to sell adapters.
Ok thanks - I already sent Tommy a email about possibility of scrap china stack for the part. will see if he has converter adapters - he is out of those actual parts.
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #18
I have done business with these folks before, they may have what you need. I might add that they can also make hoses for you.
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #19
Well we got it apart with tractor mech help - now we have another problem one part fell into the hole from hell where ever that is . looked three days and cant find - anybody have a junked control box they want to parts out - And BTW there was chewed up O ring which has been my problem before . now I have a new one.
ANY BODY WITH A SCRAPED CONTROL BOX THEY WANT TO MOVE I DOUBT THATS A ORDER PART ???
Be careful there is O rings that are rated for hot fluids. I kept using a normal one and it keep going through the system when it got hot. Once I found out there is different o rings I was good. I changed my control valves over. What a mess the original fittings are a special metric type . I ended up buying fittings and had them welded onto the original fittings. I would take your hoses off and turn your valve upside down to get what ever fell in there
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER REEFER (A52576)
2020 HYUNDAI...
2018 John Deere 1653 (A53472)
2018 John Deere...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
2025 New/Unused Wolverine Skid Steer Land Leveler (A51573)
2025 New/Unused...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
