Jinma / JW03 Backhoe Hydraulic pressure release valve
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #11
With a screwdriver, remove the adjusting screw being careful to count the number of turns (write it down).
Ooops. I guess I'll be getting a pressure gauge, and installing a port for it. :)
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #12
Good call. And be sure to use schedule 80 pipe or hydraulic fittings.
Thanks Bob
Anybody used this one ?- is 11 GPH ok for this application. Do you need to replace hose for this application ?
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #14
Thanks Bob
Eleven gallons per minute is fine for this application (I believe your tractor system is 7 gpm).
Yes, you will have to replace hose assemblies or hose end fittings with reusable fittings (this is what I had to do), or take to a hydraulic shop. One end of the hose has the metric ORFS fitting, the other end of the hoses for the new valve need to be:
  • A & B Work Ports: #8 SAE O-Ring (3/4”-16) Thread
  • Inlet Port: #10 SAE O-Ring (7/8”-14) Thread
  • Outlet Port: #10 SAE O-Ring (7/8”-14) Thread
OK Bob great info thanks so much- one more thing - Do you know what size the ORFS fittings are on the current hose at valve stack now. [ I presume both ends are the same ] I will see if someone makes a adapter from that to the 8 and 10 SAE ports.?
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #16
IIRC, the working hoses are 14mm (~1/2"), and the inlet/outlet hoses are 18mm (~3/4").
Tommy at Affordable Tractor used to sell adapters.
Ok thanks - I already sent Tommy a email about possibility of scrap china stack for the part. will see if he has converter adapters - he is out of those actual parts.
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #18
I have done business with these folks before, they may have what you need. I might add that they can also make hoses for you.
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #19
Well we got it apart with tractor mech help - now we have another problem one part fell into the hole from hell where ever that is . looked three days and cant find - anybody have a junked control box they want to parts out - And BTW there was chewed up O ring which has been my problem before . now I have a new one.
ANY BODY WITH A SCRAPED CONTROL BOX THEY WANT TO MOVE I DOUBT THATS A ORDER PART ???
Be careful there is O rings that are rated for hot fluids. I kept using a normal one and it keep going through the system when it got hot. Once I found out there is different o rings I was good. I changed my control valves over. What a mess the original fittings are a special metric type . I ended up buying fittings and had them welded onto the original fittings. I would take your hoses off and turn your valve upside down to get what ever fell in there
New/Unused 84in Quick Attach Rock Bucket (A51573)
New/Unused 84in...
JOHN DEERE LOT NUMBER 122 (A53084)
JOHN DEERE LOT...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
Curt Receiver Hitch (A51573)
Curt Receiver...
