Cub Cadet 7235 Rear Hydraulics
   / Cub Cadet 7235 Rear Hydraulics #1
powerstf
Looking to add rear hydraulic lines to my Cub Cadet 7235 for a backhoe but can't find any info. Can anyone point me in the right direction. Thanks
   / Cub Cadet 7235 Rear Hydraulics #2
Start by downloading the shop manual
Manual
In section 4 last page there is a drawing of the hydraulic block showing where a line to feed an external circuit can be connected. I marked up the drawing.
The selector lever on the block has to be moved to direct flow to these external circuits
P marked with orange arrow would be the supply to an external circuit.
Depending upon the type of circuit you would use port T or connect into Port C using a tee fitting
Since your interest is in supplying a backhoe valve, use port P as the IN on the BH valve and Tee into port C for the Tank port on the BH valve
Dave M7040
Manual
Dave M7040
Thank you very much. I appreciate it.
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
Diesel Forklift (A51691)
Diesel Forklift...
2014 LAMAR TRAILER (A52472)
2014 LAMAR TRAILER...
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
