Did the Covid shot make you cranky?
Status
Not open for further replies.
   / Did the Covid shot make you cranky? #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I had my first dose last week and noticed I was more irritable than usual for a day or two. Did anyone else have that experience?
   / Did the Covid shot make you cranky? #2
Just a sore arm after both vaccines. Wife had sore arm after #1 and Flu-Like symptoms for 1 day after shot #2. (Moderna)
   / Did the Covid shot make you cranky? #3
My wife's did! And she isn't normally either...
   / Did the Covid shot make you cranky? #5
Nope, just a sore arm for me. But I have been reading, some side effects include irritability and short temperament.
   / Did the Covid shot make you cranky? #6
After second shot Had headache for a couple hours, later in the day aching pretty much everywhere and couldn’t sleep that night but fortunately all that pretty much went away the next day.
   / Did the Covid shot make you cranky? #7
Absolutely nothing after the first shot. A small red spot & a little itching after shot number two. Lasted a day.
   / Did the Covid shot make you cranky? #8
Moderna, slightly sore arm after both doses, no other symptoms that I noticed. Have heard that the younger you are there is a greater chance of stronger symptoms due to having a better immune system.
   / Did the Covid shot make you cranky? #9
One AstraZenica jab so far (22 Jun for the second)... slightly sore around the injection area for 5-6 days after, which is longer than what I typically experience from the annual flu jab.
Any other symptoms were all in my head. o_O
Perhaps I should clarify that last statement by saying that I was hyper-sensitive to anything that 'could be' a symptom. Nothing untoward happened. :)
Status
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2017 Ford F-150...
Suspected 2k-2500 Gallon Diesel Fuel Tank w/ Containment System (A59213)
Suspected 2k-2500...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
SET OF 60" SKID STEER QUICK ATTACH PALLET FORKS (A58375)
SET OF 60" SKID...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
