Water Well Monitor
   / Water Well Monitor #1
Xfaxman
Super Star Member
Guthrie, OK
Toolcat 5610 G - Bobcat V417 - TORO+Loader
This is my way to monitor the status of the well system.
I put the gauge basically out of sight until you are standing there looking at it.
If the pressure is between cut on and cut off that is good.
If the pressure is below cut on or above cut off that is bad.
If the pressure is dropping when no water is being used, that is bad.
I just added a Tee, a short hose, a 1/4 NPT thread adapter and a gauge:
   / Water Well Monitor #3
Our pressure gauge is on our well pump pressure switch in the basement near the pressure tank and water softener.
   / Water Well Monitor #4
Great idea. It could save a trip to the garage when I start to lose pressure. I don't think it would make much difference, though. That only happens on Friday evenings about bedtime. But that way I'd know I'd be all weekend without water without making a trip to the garage to confirm. Thanks for the idea.
   / Water Well Monitor #5
Have you ever noticed that your car tends to drift towards the side of the road you are looking at?
Has your wife refused to clean the floors on the gauge side of the toilet yet?
Nope, my aim is still good! :D
   / Water Well Monitor #7
I like this idea - we have irrigation and if a leak or a hose is left on this would be an easy check vs going down and looking at the one on the pump switch.
   / Water Well Monitor #8
Good idea. And as you get older you have more opportunities to check the status, particularly during night. :giggle:
16 T/A TRASH TRAILER (A55745)
16 T/A TRASH...
2011 TROXELL 150BBL VACUUM TRAILER (A55745)
2011 TROXELL...
2014 Ford F-250 Ext. Cab Pickup Truck with Liftgate (A55852)
2014 Ford F-250...
2017 BOMAG BW211 DH5 SMOOTH DRUM ROLLER (A52707)
2017 BOMAG BW211...
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
