ericm979
Super Member
- Joined
- Nov 25, 2016
- Messages
- 5,881
- Location
- Santa Cruz Mountains CA, Southern OR
- Tractor
- Branson 3725H Deere 5105
Unlike engine oil, tractor fluid rating is approximate at best.
The Branson manual lists tractor fluids that meet Branson's spec. In mine it's Chevron THF1000 and one other that I can't remember now. You can probably get THF1000 locally. NAPA carries it, and at a good price. My local NAPAs could not get it or couldn't be bothered to get it so I have gone with fluids that match the specs Chevron lists for THF1000. These were Mobile 424 and Duraguard semi synthetic. There is some risk to this if you're under warranty as there may be differences that are not on the oil manufacturer's spec sheets. But it's worked out ok for me so far.
If you think the level is above the sight glass, jack up the rear or drive to where the tractor is pointed slightly down hill. Jacking with the tractor off would let you look at the level as the angle of the tractor changes, so you don't miss when the level is showing in the window.
