1968 JD 300 Hydraulic Pump Identification
   / 1968 JD 300 Hydraulic Pump Identification #1
joecooler
Huntsville, AL
1968 JD 300 Industrial
Hi guys, how do I know the capacity of my Hydraulic pump? I have three choices. 6.5GPM, 13GPM or 23.5GPM.
I think I found it. 13.5 GPM AR103033.
   / 1968 JD 300 Hydraulic Pump Identification #3
I see you already found it.
6.5gpm was without power steering
13gpm was with power steering
23.5gpm was an option, which I doubt not very many, if any had.
Thank you for the information. Mine is a power steering model. Good nugget.
   / 1968 JD 300 Hydraulic Pump Identification #5
Are you positive 6.5 gpm pump wasn't utilized on earlier models below serial # 045,200 that could have open center power steering?
There is a pre serial number range consideration for the pump. Mine is a later model.
   / 1968 JD 300 Hydraulic Pump Identification #7
I went by the serial number he posted
   / 1968 JD 300 Hydraulic Pump Identification #8
Sorry I misunderstood your reply. I thought you were referring to all yr models.
   / 1968 JD 300 Hydraulic Pump Identification #9
No worries
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
7046 (A50322)
7046 (A50322)
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
19200 (A50324)
19200 (A50324)
1992 SYLVAN 20' PONTOON BOAT (A51247)
1992 SYLVAN 20'...
