1968 JD 300 Hydraulic Pump Identification
   / 1968 JD 300 Hydraulic Pump Identification #1
joecooler
Huntsville, AL
1968 JD 300 Industrial
Hi guys, how do I know the capacity of my Hydraulic pump? I have three choices. 6.5GPM, 13GPM or 23.5GPM.
I think I found it. 13.5 GPM AR103033.
   / 1968 JD 300 Hydraulic Pump Identification #3
I see you already found it.
6.5gpm was without power steering
13gpm was with power steering
23.5gpm was an option, which I doubt not very many, if any had.
Thank you for the information. Mine is a power steering model. Good nugget.
   / 1968 JD 300 Hydraulic Pump Identification #5
Are you positive 6.5 gpm pump wasn't utilized on earlier models below serial # 045,200 that could have open center power steering?
There is a pre serial number range consideration for the pump. Mine is a later model.
   / 1968 JD 300 Hydraulic Pump Identification #7
I went by the serial number he posted
   / 1968 JD 300 Hydraulic Pump Identification #8
Sorry I misunderstood your reply. I thought you were referring to all yr models.
   / 1968 JD 300 Hydraulic Pump Identification #9
No worries
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
WESSEX AT110 LOT IDENTIFIER 157 (A53084)
WESSEX AT110 LOT...
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51247)
UNUSED X-STAR 101"...
