Husqvarna LGT 24K54 loses ability to go up hill
   / Husqvarna LGT 24K54 loses ability to go up hill #31
Magic! That's actually Tuff Torq boilerplate. Good eye, I've never noticed it.
I'm completely lost now (NOT the first time :)). What do you mean, Tom, by "Magic! That's actually Tuff Torq boilerplate"? I'm sensing maybe a bit of sarcasm, but, ...not sure. Still working on this mower. Rrrrrrrrrrrrrrrrr. Thanks for any help.
Odd question: Will the oil level appear similarly regardless of if I checked in the small rear hole toward the rear of tranny as opposed to the much larger diameter fill hole toward the front of the tranny, under the plastic fan above the pulley?
With my transmission still mounted in place, I've taken the rear "check hole" cap off (the smaller diameter of the two, the hole toward the rear of the tranny ...cause I can get to it and pry cap out!) and checked the fluid level and it appears quite low. It would be a LOT harder to try and pry out the other cap on the larger diameter hole (with the magnet standing vertically in it). But again, to my question, would the fluid level appear the same in BOTH HOLES, or, are they somehow separated by internal walls/duct-work and one could get a different reading depending on which hole they're checking and adding fluid into...
Hope that makes sense. I'm assuming the level will appear the same regardless of which hole I check.
SUCCESS!
I did not have enough oil in tranny. I filled it to with 3-4” of top of fill hole ...but it must’ve needed to bleed etc and fill in all internals. Like an idiot, I didn’t think to check the explicit capacity of the K46 and compare to how much of the 3L jug I opened... I was still about a liter short. Filled it, ran back and forth a bunch - then drove around yard. Brandy new.
THANK YOU ALL FOR YOUR HELP!
Happy mowing (not towing 🤠😎).
Jay
   / Husqvarna LGT 24K54 loses ability to go up hill #35
Congrats. I can’t check mine unless I pull the whole axle, which I probably should do.
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53473)
2021 NEW HOLLAND...
FORD F750 XL SUPER DUTY TRUCK (A51406)
FORD F750 XL SUPER...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2011 Genie GRC-12 Man Lift (A53117)
2011 Genie GRC-12...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53473)
2003 International...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
