Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,999
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
The rest of the story....
I pulled out my 8-3 wire... WHAT? Doesn't EVERYONE have a 50' run of 8-3 wire for circumstances just like this????!!
So I pulled it out. Went into town to get a new outlet. (30 miles round trip). Got a new outlet, got a plastic box for it and a new cover. I wanted to be able to hobble along with this in the event I need to rip into walls.
Got the thick wires cut down to fit things for a trial run.....and it didn't work. The LIGHTS worked but the heater didn't.
WHAT?
Get my circuit tester out (the beeper not DVM) and don't you know one wire was beeping.....the other.....not.
Double WHAT??
I'm immediately suspecting things....but need to rule out others. Pull out the DVM and test each circuit at the outlet. Indeed, red wire, hot, black wire dead.
My breaker is bad.
Well, I can test for that.... it's a 40 amp and I just happen to have an extra 50 amp in the garage....WHAT, doesn't everyone have an extra 50 amp double pull laying about??!
Get the 50 amp out and now I'm convinced enough that this is indeed the problem (in spite of all the testing/probing I did earlier) I put it into the box, wired it up. Disassembled the new outlet hanging on my fancy extension cord.... went to the laundry room and without bothering to test things, wired it up, closed it up (put cover plate on) and turned dryer on.
As it happens, my wife was there during this when I told her it was going to work.
She thinks I walk on water. (it might only be a damp sidewalk but hey, water is water!!!!)
She's back in business although I need to head BACK into town to get a 40 amp and swap it out.
WHAT?
Double WHAT??
My breaker is bad.
