Mitsubishi 1650 4x4 with front loader & 3 pt wont work
   / Mitsubishi 1650 4x4 with front loader & 3 pt wont work #1
pacer1980
Member
Greenwood La USA
Kubota BX25D Mitsubishi D1650
As title sez, I have a Mitsu 1650 with FEL that performs perfectly, but the 3 point wont work.
The control under seat does nothing - I'm thinking thats supposed to control the 3 pt??
But from what I can determine all the hydraulics are only connected to the FEL - would think there should be a valve to switch from one to other??? On the pump bottom is a small steel line portion conx to hose going to side of tranny - pressure route??. Large pipe coming out of top of pump going to bottom of tranny - return route??
I've had the little guy about 3-4 yrs and have never really needed the 3 pt, but right now I DO need it. I got a box blade with it and PO hooked it up and when I got home unhooked it. Way some time later I needed the 3 pt but couldnt figure out how to do it.
So, should'nt there be a valve to switch between the 2??
   / Mitsubishi 1650 4x4 with front loader & 3 pt wont work #2
Can you show the second image without your left comment?
It looks a lot like they bypassed the hydraulic adapter port and disabled the three point.
On yours I am fairly positive it is on the front flat part under your comment bubble.
This is just from the other side, will it do to help explain
Is this adapter available do you know? From Messik or ???
   / Mitsubishi 1650 4x4 with front loader & 3 pt wont work #6
This is the basic configuration (it's out of the MT160-MT180 manual and the port is on the side and not the front, but the premises are the same).
So I would have to have this adapter? Just check the mitsu suppliers and see if there's any available...
Or could I just add a diverter valve....
2006 BOBCAT T190 SKID STEER (A52707)
2006 BOBCAT T190...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2010 Toro Workman MD (A55973)
2010 Toro Workman...
2018 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55852)
2018 Chevrolet...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A57193)
UNUSED FUTURE SB45...
2019 Yongfu Scooter (A55853)
2019 Yongfu...
