Engine Oil
   / Engine Oil #1
TVZ
MF 1726E
What's best for my 2018 MF1726E--Synthetic oil? Synthetic blend? or regular (good quality) oil?
Thnx...
   / Engine Oil
The manual does not specify whether synthetic or other is best. It just says to use 5W-30. I thought I might get an answer from someone knowledgeable here...
   / Engine Oil #4
I would use Rotella T6 synthetic.
   / Engine Oil #6
Opinions vary on synthetic vs. blend vs. regular oil. Synthetic oils generally excel in extreme conditions and environments. With modern machinery it is much more important to use the correct API rated oil, particularly with recent emissions equipment.
My personal preference has been fully synthetic oils for many years. YMMV
  • Good Post
Reactions: TVZ
   / Engine Oil #7
5w30 is what I used in the VW TDI for near 7 years and near 70k miles, changed every 10k miles. Used same 5w30 Castrol from VW dealer in JD 2025R and Isuzu generator. Can get 0w30 M1 EsP from Advance Auto now. That's what is in the 2025R now.
  • Good Post
Reactions: TVZ
   / Engine Oil #8
If you check with a distributor I think you'll find 5W-30 is a synthetic blend whether it says so or not.
  • Good Post
Reactions: TVZ
   / Engine Oil #10
Why is this still a question in 2021? Use synthetic, be happy.
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
Towable Orchard Sprayer (A55851)
Towable Orchard...
3pt Hay Spear (A56469)
