Slow Leak of Filled Tire
   / Slow Leak of Filled Tire #1
Dennisfly
Gold Member
Lake Anna, Virginia and Alleghany County, VA
John Deere 4410
I have a JD 4410 with a slow leak in the left rear tire that needs to be aired up every week and a half or two. It is a tubeless turf tire that's filled and I see no fluid leaking. I replaced the valve core and it made no difference. The tire/wheel weighs over 700 Lbs so I don't want to take it off to try and submerge. Running water over the outside shows nothing. Should I drain it and take it to a tire shop or are there other better ideas?
   / Slow Leak of Filled Tire #2
I had a similar issue but on a front tire.
I didn’t remove the tire. I sprayed Windex on the tire. The slow leak - very small thorn - showed itself by bubbling. I think the Windex tends to show the bubbles better than plain water.
It took me a while to find but, if air is leaking out the tread, it will eventually bubble.
Good luck.
MoKelly
   / Slow Leak of Filled Tire #3
Simple solution is go to your JD dealer and get some of their tire sealant for liquid filled tires. That stuff is amazing and will seal off any small leak. I have used it on multiple tires in the past with no more flats.
   / Slow Leak of Filled Tire #4
If you simply want to find the leak try a solution of liquid dishwashing detergent and water.
   / Slow Leak of Filled Tire #6
All good ideas. I didn't know there was such a thing as a filled tire sealant. That's what is great about this site!
That stuff replaces 10% of your tire fill. If you have 50gal. fill in each tire, that's ~$170 per tire. o_O
MULTI SEAL HYDRO 1500
   / Slow Leak of Filled Tire #7
That is not the stuff I am talking about. The JD stuff will work and it takes a lot less. It is not that expensive. Maybe $50 at the most. Most JD dealers carry it and if not they will order it. The only sealant I will use.
   / Slow Leak of Filled Tire #8
Got a name for it? That Multi Seal / Flatout stuff is *amazing* as well, but if I can get it cheaper and it will last in the tire just as long...
   / Slow Leak of Filled Tire #9
It is called John Deere Tire Sealant. They have one version for air and one for liquid.
   / Slow Leak of Filled Tire #10
Thanks.. I'll probably try some. The Flatout stuff works for 1/2" officially and I had it seal larger. Sealed one tire with just over 1/4" hole in one revolution and that one already had Slime (crap stuff).
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
Club Car Carryall 500 Electric Utility Cart (A51691)
Club Car Carryall...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
John Deere Z930M (A50121)
John Deere Z930M...
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
John Deere Hay Rake (A50515)
John Deere Hay...
