Kubota L3901 sluggish in 2nd gear
   / Kubota L3901 sluggish in 2nd gear #1
kbernard
Kubota L3901
I have a Kubota L3901 with 136 hrs. It has become sluggish in 2nd gear and will not climb a hill. I changed the fuel filter, emptied the separator and cleaned, turned valve on to separator and getting good flow. The hydraulic oil is clear.
Other than cleaning the elbow at the fuel filter any other suggestions.
Thanks
Kendall
   / Kubota L3901 sluggish in 2nd gear #2
I would be tempted to check hydraulic fluid level, not sure if there is an adjust in the linkage of the hydrostatic pedal but that would come next.
I did check the hydraulic fluid level and it is where it should be. The fluid is also clear. There is no play in the pedal. Any other suggestions would be appreciated.
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2004 INTERNATIONAL 4300 BOX TRUCK (A54607)
2004 INTERNATIONAL...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
1996 Ingersoll-Rand VR642C (A47477)
1996...
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
