3pt hitch - 5th wheel/gooseneck
   / 3pt hitch - 5th wheel/gooseneck #1
horsebroke
Western Colorado
TYM T450
I have 2ea trailers - one a gooseneck horse trailer (appx 28 feet), and a 25-foot 5th wheel camper.
I'd like to be able to move them around with my tractor.
I've seen gooseneck hitches for 3-point connection on the tractor - but have never seen a hookup for 5th wheel..
Anyone ever seen one, and know where I'd find one?
thank you in advance
   / 3pt hitch - 5th wheel/gooseneck #2
I have not seen a 5th wheel hitch for the 3-pt trailer movers. However, they do make gooseneck to 5th wheel hitch adapters. You can try that and see if it'll work on your trailer mover. If I remember correctly, Reese or Husky makes them. I was considering the same issue awhile back, but never really followed through with it.
Hawk
   / 3pt hitch - 5th wheel/gooseneck #3
B&W makes an 5th wheel adapter that fits in their gooseneck hitch. If you had a tube at the top of the 3pt attachment you could put either in to move trailers.
   / 3pt hitch - 5th wheel/gooseneck #4
Sorry I don't have any pics to post.
I built my own on the box blade just behind the top link connection.
It consist of a piece of pipe (sleave) with an ID the same size (a hair bigger actually) as the pin on the 5th wheel. It has a flat plate or collar around the top of it for the pin box to rest on. Then I have a pipe with a 2 3/8 ball welded to the top of it that I can slide into and pin in the sleave.
I hope this makes sense. I try to get some pic's and post back this evening.
   / 3pt hitch - 5th wheel/gooseneck #5
Here is the box blade with the mods to move a 5th wheel and gooseneck.
   / 3pt hitch - 5th wheel/gooseneck #6
Neat idea Firedog. Next time I get to welding on the box blade.. I'd like to do something like that.
-Luke
   / 3pt hitch - 5th wheel/gooseneck #7
Hate to revive a 10yo thread, but man does this hit the spot. I'm taking delivery of a 30' 5er that will likely spend the rest of its days on my property. Without a 3/4 or 1 ton to move it, my intent is to use the tractor when needed. It is amazing to think that there are so few solutions - and that this one thread still comes up near the top with Google. Just wanted to thank @firedog for the pictures. I'll start the hunt for a metal supplier this week.
   / 3pt hitch - 5th wheel/gooseneck #8
I welded a 2 5/16ths" hitch ball to the top of my trailer mover hitch. That works for goose neck as that's mostly what I move. For 5th wheel I just slip a piece of pipe over the ball. Works for me. If some one want's pictures I can post them.
   / 3pt hitch - 5th wheel/gooseneck #10
Thanks for all the details. My RV has a 5th wheel king pin, not a gooseneck. What appeals to me about firedog's approach is that I can utilize my boxblade by simply welding on a cylindrical metal sleeve and a flat disc. Gotta say, that "tractor" of yours in the photos looks neat.
   / 3pt hitch - 5th wheel/gooseneck #11
Safety reminder: I use my 3 point hitch to move several GN trailers. In all cases, be aware that you're pulling from above the level of the rear axle. Too light of a tractor or too much trailer will cause the tractor to rear up and crush the operator. This can also happen if the trailer snags an object or wheel drops into a hole. (more likely and unexpected during a move)
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2014 BOBCAT E32 EXCAVATOR (A60429)
2014 BOBCAT E32...
