3pt hitch - 5th wheel/gooseneck
   / 3pt hitch - 5th wheel/gooseneck #1
horsebroke
Western Colorado
TYM T450
I have 2ea trailers - one a gooseneck horse trailer (appx 28 feet), and a 25-foot 5th wheel camper.
I'd like to be able to move them around with my tractor.
I've seen gooseneck hitches for 3-point connection on the tractor - but have never seen a hookup for 5th wheel..
Anyone ever seen one, and know where I'd find one?
thank you in advance
   / 3pt hitch - 5th wheel/gooseneck #2
I have not seen a 5th wheel hitch for the 3-pt trailer movers. However, they do make gooseneck to 5th wheel hitch adapters. You can try that and see if it'll work on your trailer mover. If I remember correctly, Reese or Husky makes them. I was considering the same issue awhile back, but never really followed through with it.
Hawk
   / 3pt hitch - 5th wheel/gooseneck #3
B&W makes an 5th wheel adapter that fits in their gooseneck hitch. If you had a tube at the top of the 3pt attachment you could put either in to move trailers.
   / 3pt hitch - 5th wheel/gooseneck #4
Sorry I don't have any pics to post.
I built my own on the box blade just behind the top link connection.
It consist of a piece of pipe (sleave) with an ID the same size (a hair bigger actually) as the pin on the 5th wheel. It has a flat plate or collar around the top of it for the pin box to rest on. Then I have a pipe with a 2 3/8 ball welded to the top of it that I can slide into and pin in the sleave.
I hope this makes sense. I try to get some pic's and post back this evening.
   / 3pt hitch - 5th wheel/gooseneck #5
Here is the box blade with the mods to move a 5th wheel and gooseneck.
   / 3pt hitch - 5th wheel/gooseneck #6
Neat idea Firedog. Next time I get to welding on the box blade.. I'd like to do something like that.
-Luke
   / 3pt hitch - 5th wheel/gooseneck #7
Hate to revive a 10yo thread, but man does this hit the spot. I'm taking delivery of a 30' 5er that will likely spend the rest of its days on my property. Without a 3/4 or 1 ton to move it, my intent is to use the tractor when needed. It is amazing to think that there are so few solutions - and that this one thread still comes up near the top with Google. Just wanted to thank @firedog for the pictures. I'll start the hunt for a metal supplier this week.
   / 3pt hitch - 5th wheel/gooseneck #8
I welded a 2 5/16ths" hitch ball to the top of my trailer mover hitch. That works for goose neck as that's mostly what I move. For 5th wheel I just slip a piece of pipe over the ball. Works for me. If some one want's pictures I can post them.
   / 3pt hitch - 5th wheel/gooseneck #10
Thanks for all the details. My RV has a 5th wheel king pin, not a gooseneck. What appeals to me about firedog's approach is that I can utilize my boxblade by simply welding on a cylindrical metal sleeve and a flat disc. Gotta say, that "tractor" of yours in the photos looks neat.
   / 3pt hitch - 5th wheel/gooseneck #11
Safety reminder: I use my 3 point hitch to move several GN trailers. In all cases, be aware that you're pulling from above the level of the rear axle. Too light of a tractor or too much trailer will cause the tractor to rear up and crush the operator. This can also happen if the trailer snags an object or wheel drops into a hole. (more likely and unexpected during a move)
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
SWICT 66" SKID STEER BUCKET (A60430)
SWICT 66" SKID...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
