Boots, what are you wearing, what do you recommend?
   / Boots, what are you wearing, what do you recommend? #1
Number15
Gold Member
Rhea County TN
AC 7600 TTR, Branson 5520CH, Grasshopper 928D2
Fairly new to the rural life. Quickly learning sneakers do not cut it for most things I am doing on the property. I have a pair of Keen Durand boots and I like them but I am looking for a second pair. I learned from my time in the military that it is good practise to rotate boots.
So I am looking for recommendations from the people out there. Just fyi I don't skimp on footwear or mattresses as most of my life is spent in one or the other :)
So whatcha got and whatcha recommend
   / Boots, what are you wearing, what do you recommend? #2
What kind of work? Love my White's for forestry and some tractor stuff but if it's commonly muddy I won't wear them in that, Muck boots are pretty good but hot, lots of options depending on the need.
So I would say general yard work, tractor work, lawn mowing etc. I have ~85 acres I am taking care of now so I will have some future tree work, general cleanup and a small ~1 acre garden. Looking for something that will handle feet getting wet from dew, small puddles and a little mud. Nothing to heavy but durable. I feel the sole of my durand are wearing to fast because I think they are meant more for hiking but time will tell.
tl:dr a general "work" boot style I guess is what I am looking for. Also interested in what others use/like.
   / Boots, what are you wearing, what do you recommend? #6
project farm recently did a boot test. the keen workboots were highly rated. i may try a pair of their slip ons next time. i do like my current wolverines, and they were my favorite while working offshore in the oil industry. I did not know keen was making stuff in the USA. wolverine is based in Rockford, Michigan and also has some made in USA stuff. i wore out redwings and several other brands before i settled on the wolverines, and I used them for my last few years in the field. composite toe.
i doubt any manufacture has all the components come form the USA. thread, rubber, foam, leather, laces, eyelets, etc.
   / Boots, what are you wearing, what do you recommend? #7
For mud, I like the Gemplers "Brown Bear" rubber (PVC) work boots, comes in steel toed and not. Their tread is really good about shedding mud.
Leather...sorry. I don't have a recommendation.
All the best,
Peter
   / Boots, what are you wearing, what do you recommend? #8
During the dry times - a low cut pair of Keens. When & if it ever gets wet - Mucks. Winter - Sorels.
   / Boots, what are you wearing, what do you recommend? #9
My everyday work boots are Red Wing upper leather with composite toe, for out side snow/rain work Mucks are used. The Red wings are water resistance where as the Muck are water proof. Also use motorcycle boots as well.
Dave
   / Boots, what are you wearing, what do you recommend? #10
+1 on the wolverines (or its sister brand: Bates). I have had a few pairs of each that have held up relatively well and I tend to be rather rough on footwear. However, needing a wider shoe/boot also cuts down on the brands that could/would fit my feet so. 🤷‍♂️
Have also learned it's worth getting footwear that fits both length and width when new as it makes for longer wearing and a more comfortable time - and that's especially true with any type of safety toe footwear.
Though whichever brand you get, if you start frequently snapping boot laces it might be worth getting a pair of kevlar laces (while they aren't cheap, they can/do outlast the boots).
   / Boots, what are you wearing, what do you recommend? #11
Justin cowboy with a rubber sole for most around the property stuff. I have some labonville Kevlar's for heavy forestry days, but I find they aren't the most comfortable if I am on slopes/rocky terrain. Ill look at a few others but yes American made is also my preference.
   / Boots, what are you wearing, what do you recommend? #12
I use the ITS tactical ones. bought 3 pair years ago and 2 are still in the packaging.
   / Boots, what are you wearing, what do you recommend? #13
Does anyone feel Keens are hot? I usually shy away from waterproof boots because they don't breathe well. I see most of the Keens are waterproof. Feedback appreciated.
   / Boots, what are you wearing, what do you recommend? #14
The keens do run warm as waterproof. But I still use them in the current heat and not too bad.
   / Boots, what are you wearing, what do you recommend? #15
It all depends on what I'm doing...........e.g. snow.....below freezing.....mud....really muddy... chain sawing......mowing.......sloppy painting or caulking......dragging my feet on concrete or rocky dirt.....getting on the roof or standing on a ladder..........dressed up for church.....
I must have about 15 pairs of assorted boots....some fairly new....some shot to hellz but usable....... and the appropriate sock to go with them.
Cheers,
Mike
   / Boots, what are you wearing, what do you recommend? #16
I am clearing land with a lot of underbrush, pine cones, mud and it is steep in places.
Solomon hiking boots. Great traction on loose soil, silt, or leaves. Good support on ankles for rough terrain.
   / Boots, what are you wearing, what do you recommend? #17
I have a pair of Danners that have lasted for years. More recently, I had a pair custom made for my feet, which cost me $350, about $50 more than the Danners cost years ago. Keep them greased and use cool circulating air to dry them, never get them hot, and they will last and last. My Danners have gone through two sets of vibram soles, and have thinsulate lining that used to be waterproof but is getting pretty worn. The guy who made my boots said if I want waterproof, buy waterproof socks.
Never pour concrete in leather boots. It will ruin them. Muck boots are your friend.
   / Boots, what are you wearing, what do you recommend? #18
I use Nicks boots with the logger heel. Made to your feet by measuring and sending you try on boots to check the fit. After that your boots are made and shipped. After break in those are the most comfortable boots. All US hand made. Expect to pay around 500 dollars
   / Boots, what are you wearing, what do you recommend? #20
Good to see more people doing their best to buy American.
We can turn the tide in this country just by spending our money domestically.
1454 (A57192)
1454 (A57192)
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
