Del Morino mower finally broke
   / Del Morino mower finally broke #1
joecoin
Gold Member
Milan, OH
Steiner 420 / Grillo 107d
I've been abusing my Del Morino brush mower for 7 years. It finally decided it had enough. Broken weld and broken drive shaft.
   / Del Morino mower finally broke #2
That is certainly a catastrophic failure. Was weld faulty or just too much stress ?
   / Del Morino mower finally broke #3
Brush Mowers do live a tough life. How many hours would you estimate? What were you cutting?
Maybe 1000 hours, maybe more. Hard to guess.
I cut everything I can with it. It's been repaired many times for more minor issues.
I believe this issue was caused by me lifting the front end (by pushing down on the handles) when turning.
I had the part welded and have the new shaft, just got to put it back together now.
   / Del Morino mower finally broke #5
1000 hours of brushhogging! that impressive, both for the machine, and for you. Im not to impressed with my BCS bushhog. It brutal to turn with my BCS 770. I really have to manhandle it.
I'm going to rely on my steering brakes completely now, probably wear them out eventually.
Don't have brakes on your 770?
   / Del Morino mower finally broke #7
Brakes don’t turn it fast enough, the skids get caught on the brush. A caster would be nice instead of skids.
I was just thinking about this, but I believe the wheels would get in the way for me. I mow a lot in wooded areas, lots of trees to hit with wheel(s). I run mostly in 1st gear, so speed of turning is not an issue. Maybe a single wheel out front?
I use my Zanon finish mower in tall grass/meadow areas and the wheels are a big help there.
2007 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A56138)
2007 INTERNATIONAL...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
Freightliner Tender Truck - Adams Tender (A55302)
Freightliner...
