Del Morino mower finally broke
   / Del Morino mower finally broke #1
joecoin
Milan, OH
Steiner 420 / Grillo 107d
I've been abusing my Del Morino brush mower for 7 years. It finally decided it had enough. Broken weld and broken drive shaft.
   / Del Morino mower finally broke #2
That is certainly a catastrophic failure. Was weld faulty or just too much stress ?
   / Del Morino mower finally broke #3
Brush Mowers do live a tough life. How many hours would you estimate? What were you cutting?
Maybe 1000 hours, maybe more. Hard to guess.
I cut everything I can with it. It's been repaired many times for more minor issues.
I believe this issue was caused by me lifting the front end (by pushing down on the handles) when turning.
I had the part welded and have the new shaft, just got to put it back together now.
   / Del Morino mower finally broke #5
1000 hours of brushhogging! that impressive, both for the machine, and for you. Im not to impressed with my BCS bushhog. It brutal to turn with my BCS 770. I really have to manhandle it.
I'm going to rely on my steering brakes completely now, probably wear them out eventually.
Don't have brakes on your 770?
   / Del Morino mower finally broke #7
Brakes don’t turn it fast enough, the skids get caught on the brush. A caster would be nice instead of skids.
I was just thinking about this, but I believe the wheels would get in the way for me. I mow a lot in wooded areas, lots of trees to hit with wheel(s). I run mostly in 1st gear, so speed of turning is not an issue. Maybe a single wheel out front?
I use my Zanon finish mower in tall grass/meadow areas and the wheels are a big help there.
2008 FORD F450 SERVICE TRUCK (A56129)
2008 FORD F450...
Enmark Z Spray (A53316)
Enmark Z Spray...
King Kutter TG72 Rotary Tiller Tractor Attachment (A54811)
King Kutter TG72...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
New/Unused CFG Industrial QK18R Mini Excavator (A54865)
New/Unused CFG...
