rear rims GC2400 where to buy?
   / rear rims GC2400 where to buy? #1
Dmacleo
Etna, Maine
2010 MF GC2400 Owner, 2012 MF1532 User
looking to setup "hot" swappable winter tires for GC2400.
massey rim 3609405M1 is part number and runs around 120$ each.
wondering if anyone knows where to buy used/refurbed ones.
not finding much on google but looking for these items is new to me.
   / rear rims GC2400 where to buy? #2
A part number is fine, but what size rim is it? Even letting us know what size tire goes on it would help!
David from jax
tire size is 26x12-12 massey parts book lists it as 12MM X 10.5MM for rear, but those dimensions seem little odd.
fwiw gc2300 same rim but 1700 series different number
   / rear rims GC2400 where to buy? #4
This is what tractordata has to say, but they have been known to be wrong. We will also need to know the bolt circle size, lugnut size, and the center hole size. Probably a common size rim.
David from jax
Standard tires (ag):Front: 18x8.50-10. Rear: 26x12.00-12
Lawn/turf front:18x8.50-10
Lawn/turf rear:26x12.00-12
Industrial front:18x8.50-10
Industrial rear:26x12.00-12
yeah I'll have to measure that stuff later, I don't mind paying 120 each if needed just wondered if there was any sort of aftermarket for these.
those tire measurements are correct btw and ag tires will fit same rims also.
   / rear rims GC2400 where to buy? #6
Of course try eBay (which will be high if found), Craigslist, etc. on line. Unlikely to find them. There is a company that makes rims for nearly all sorts of tractors (can't recall name) but you should be able to find them on-line. Most of the big tractor/farm equipmwent shows (like the PA one near State College coming up in a couple of weeks) always has a wheel vendor there. You should be able to get the name of the company by looking throught the vendors list for the PA Ag Progress Days show. I'm not up on pricing but $120 might not be too bad actually. I bought a set for an antique MH Pacer a few years back and they were cheaper than that. Finally, call Wengers of Myerstown in eastern PA (the biggest tractor salvage yard in the northeast USA.) Whether they have any or not they are very good about helping folks find things.
yeah checked ebay and craigslist but no luck.
if company not already tooled up to make them then yeah, 120 is best price.
I'll take look at vendor list this week and see, thanks for info.
  • Good Post
Reactions: JWR
   / rear rims GC2400 where to buy? #8
This guy sets up duallies so he might have a way to get rims.
I had actually seen some of his stuff before, iirc he uses stock rims and just machines out spacers
   / rear rims GC2400 where to buy? #10
Check your bolt spacing, center hole, and backset measurement.
Miller Tire also sells rims:
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2016 John Deere 410E 40 Ton Articulated Off-Road Dump Truck (A50322)
2016 John Deere...
RoGator 844 sprayer (A50490)
RoGator 844...
2012 MACK CHU613 DAY CAB FLAT TOP ROAD TRACTOR (A51243)
2012 MACK CHU613...
