Tractor PTO shaft cover made with orbit 4" sprinkler popup head.
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #1
jkk04
Gold Member
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
Have you ever thought about making PVC or Rubber PTO shaft cover?
Hope, this video answers the question.
John's Ranch
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #2
I just use a rubber hose.
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #3
I have the one that came on mine enew but I don't use it. Why are you covering your PTO shaft?
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #4
Just need to put a zerk in the end and pump it full of grease.
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #5
One should always keep one's output shaft covered.
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #6
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #7
The reason is to keep the PTO shaft clean (I put grease film in mine before I put it on) and it keeps the shaft from rusting, dusting when I'm not using it.
2005 GEHL CTL70 TURBO SKID STEER (A51242)
2005 GEHL CTL70...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
TEST BID LOT (A50775)
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
