Tractor PTO shaft cover made with orbit 4" sprinkler popup head.
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #1
jkk04
Gold Member
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
Have you ever thought about making PVC or Rubber PTO shaft cover?
Hope, this video answers the question.
John's Ranch
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #2
I just use a rubber hose.
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #3
I have the one that came on mine enew but I don't use it. Why are you covering your PTO shaft?
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #4
Just need to put a zerk in the end and pump it full of grease.
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #5
One should always keep one's output shaft covered.
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #6
   / Tractor PTO shaft cover made with orbit 4" sprinkler popup head. #7
The reason is to keep the PTO shaft clean (I put grease film in mine before I put it on) and it keeps the shaft from rusting, dusting when I'm not using it.
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
