dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,514
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Oldnslo- Following you 5x5. I was wondering myself if that was the case, and it makes sense.
Moss - I guess the main point from your note is that hydraulics generate a bunch of heat, no matter what you do, and I get it. My problem is how much and how do I handle it. A radiator and fan are a no-go. I could possibly do just a radiator, but without the fan that will limit how effective it is.
LD1 - Unfortunately I really can't answer your question on how much pressure the broom needs to keep going. No good way to figure that out other than experimentally and I don't get the luxury of working it out on a prototype here as this IS the prototype! There must be significant drag from the bristles spinning on the ground and moving snow or whatever debris is in question so it may be a full 2000 psi or a goodly fraction of it. On the plus side the circuit is pretty simple without a lot of restrictions, other than the relief and the diverter for the angle cylinder. And of course the work done by the motor. I don't see me fitting 40 gallons in this no matter what. I can manage up to about 25 gal but that's about it.
Hmmm. There might be room for a rad and fan on one side if I use only one smaller tank on the other side. I'd have to work out power to the fan but I already need a little bit of wiring to handle the diverter already so maybe it isn't so far-fetched to do. In that case I am able to have at most 15-16 gal reservoir.
Thanks for all the input!
