Cub Cadet LT1045. Slow speed problem fix
   / Cub Cadet LT1045. Slow speed problem fix #1
jkk04
Gold Member
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
If you have slow speed problem on the mower, try to find adjust speed linkage first.
The problem should be solved easily.
Thank you
John
   / Cub Cadet LT1045. Slow speed problem fix #2
Thanks for sharing. (y)
I have Cadet 1046LT recall only once belt coming off do to lack of keeping debris build up.
   / Cub Cadet LT1045. Slow speed problem fix #3
belt tendtioner on deck lt1045 how do you adjust it? cub cadet
To my knowledge, the belt tensioner on the LT1045 mower deck is not adjustable.
   / Cub Cadet LT1045. Slow speed problem fix #5
anyone know the size of the deck belt on LT 1045 CUB
   / Cub Cadet LT1045. Slow speed problem fix #6
That depends which belt is spec'd for your machine. Look under the hood on the decal for the part number. If it is a 954-0461 it is a 1/2x78. Otherwise post back for fire up the Googler with your part number. Not all are even sized belts.
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
