Kubota hydraulic cylinder seal replacement-Where's the o-ring?
   / Kubota hydraulic cylinder seal replacement-Where's the o-ring? #1
joea99
Marbletown NY
Kubota B21, JD 240GT
New question on redoing the seals. Put the seals in the cap without too much difficulty. I used the 3D printed tools to get two of the large diameter seals on. Worked great. Oddly, the hardest one to get in, the dust seal, is the one I expected NO trouble with.
Got ready to think about doing the piston seals when I noticed the smaller o-ring, that goes in the piston "head" and bears up against the shoulder/stop on the rod is not in the seal kit.
Puzzled, I went to the IPL and, sure enough, that o-ring is not shown. Not for any of the cylinders, not just the dipper stick cylinder. There has been an o-ring in that position in every cylinder I've done. All 3 of them.
So, how do I get a replacement. I'm not a hydraulics expert by any stretch but I'd say if it is there, it serves a purpose and should be renewed. Sure, I could take to to a hydraulics shop and ask them to sell me one, but, why isn't a cheap (?) o-ring on the IPL and include in the kit? I can ask Messicks that question on Monday, but, if Kubota does not show it . . .
I'm sure this is not a new problem, just new to me.
   / Kubota hydraulic cylinder seal replacement-Where's the o-ring? #2
I worked at a Kubota dealer. They quit sending and we quit installing those o rings. It will work fine without it. I did all the cylinders during my time there. I mean I was the cylinder fixer.
That astonishes me. I'd think there could be leakage (bypass) at that point. Guess not.
I got one from place down the road sells fitting and makes hoses. Farms out the cylinder work.
Question about the cylinder head (cap). Is there a torque value, or just "good and tight"?
Gudntite seems to be working just fine.
2018 MERTZ MANUFACTURING 2500HP QUINTUPLEX FRAC PUMP (A55745)
2018 MERTZ...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
2018 John Deere 4066R (A53314)
2018 John Deere...
