Need spray to kill these woody plants
   / Need spray to kill these woody plants #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Along my spruce treelines are these woody type plants that grow right through the spruce branches. They would eventually grow pretty tall. If I can catch them away from the spruce, repeated sprays with a 2% glyphosate concentrate mix will kill them. So will 2,4-D. I don't mind occasionally spraying a spruce branch or two but fear repeated sprayings might hurt them. I'm not even sure what these plants/potential trees are.
Anyone have an idea of a spray herbicide I could use that I could spray on the plant and because of proximity also spray the spruce?
   / Need spray to kill these woody plants #2
Pic one is a mulberry. Best to just pull them up while small. The other doesn't register with me yet. For scrub that pops up under conifers I use triclopyr in the weed Wick. A little goes a long way and no collateral damage from overspray.
   / Need spray to kill these woody plants #3
I just reach in with loppers and cut/pull them out..?
Thank you. I'll look into it.
Thank you. That's what I have tried to do but they grow back. Worse, I get a facefull of spruce needles plus some are not possible to reach. A spray with no collateral spruce damage would be easy to use, reach in easily and solve the problem.
   / Need spray to kill these woody plants #6
Get a sprayer with a wand and mount an inverted funnel over it. That allows you to direct the spray better.
   / Need spray to kill these woody plants #7
Adjust the nozzle for a a spatter of droplets vs an actual 'spray' that will drift. Might not need the funnel but it couldn't hurt to add that. If you lop low slather/glob/paint glyoho concentrate (~40%) on the stub ends within 10-15 min to kill the roots vs stimulate a 'pruning response' and regrowth.
Wow, good idea that I forgot all about that. But still, I need a stronger chemical to kill those things. They die hard.
I have cut some and touched the cut with straight 41% glyphosate but mostly the stump is buried in six feet of tangled brush.
   / Need spray to kill these woody plants #10
If you are using a wand with the funnel over it you can use roundup. Just be careful not to get any on the tree. You can also use a 2L bottle and cut the bottom off. I use that to "weed" in the flower bed. Just cover the weed and spray.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
KJ 42'x30' Metal Storage Shed (A50121)
KJ 42'x30' Metal...
