Need spray to kill these woody plants
   / Need spray to kill these woody plants #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Along my spruce treelines are these woody type plants that grow right through the spruce branches. They would eventually grow pretty tall. If I can catch them away from the spruce, repeated sprays with a 2% glyphosate concentrate mix will kill them. So will 2,4-D. I don't mind occasionally spraying a spruce branch or two but fear repeated sprayings might hurt them. I'm not even sure what these plants/potential trees are.
Anyone have an idea of a spray herbicide I could use that I could spray on the plant and because of proximity also spray the spruce?
   / Need spray to kill these woody plants #2
Pic one is a mulberry. Best to just pull them up while small. The other doesn't register with me yet. For scrub that pops up under conifers I use triclopyr in the weed Wick. A little goes a long way and no collateral damage from overspray.
   / Need spray to kill these woody plants #3
I just reach in with loppers and cut/pull them out..?
Thank you. I'll look into it.
Thank you. That's what I have tried to do but they grow back. Worse, I get a facefull of spruce needles plus some are not possible to reach. A spray with no collateral spruce damage would be easy to use, reach in easily and solve the problem.
   / Need spray to kill these woody plants #6
Get a sprayer with a wand and mount an inverted funnel over it. That allows you to direct the spray better.
   / Need spray to kill these woody plants #7
Adjust the nozzle for a a spatter of droplets vs an actual 'spray' that will drift. Might not need the funnel but it couldn't hurt to add that. If you lop low slather/glob/paint glyoho concentrate (~40%) on the stub ends within 10-15 min to kill the roots vs stimulate a 'pruning response' and regrowth.
Wow, good idea that I forgot all about that. But still, I need a stronger chemical to kill those things. They die hard.
I have cut some and touched the cut with straight 41% glyphosate but mostly the stump is buried in six feet of tangled brush.
   / Need spray to kill these woody plants #10
If you are using a wand with the funnel over it you can use roundup. Just be careful not to get any on the tree. You can also use a 2L bottle and cut the bottom off. I use that to "weed" in the flower bed. Just cover the weed and spray.
377694 (A51572)
377694 (A51572)
2025 25ft 1 Gauge 800 Amp Booster Cables (A50323)
2025 25ft 1 Gauge...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
Hunter GSP9712 Tire Balancer (A50121)
Hunter GSP9712...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2019 MITSUBISHI OUTLANDER SPORT (A52472)
2019 MITSUBISHI...
