Need tool to put tubing on nipple
   / Need tool to put tubing on nipple #1
RSKY
Elite Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
The mechanics at a factory I worked at had a tool they used to put rubber hose/tubing on a nipple. It looked like a set of pliers with clamps on the jaws. I needed one today to repair a leak on a 12-volt sprayer. Worked on it an hour and finally got hose on to where I could clamp it. Sprayed 1/8 of what I intended and pump quit. AARRRGGGGHHHHH......
I need one of these once every five years but I would have paid $50+ for it today. Cannot find one online and I know I just don't have the right name in the search.
Thanks.
RSKY
   / Need tool to put tubing on nipple #2
Are you talking about Hose Grip Pliers?
No, had my hopes up but those are not the tool. It was like two of those attached together and he would lock one on the nipple and grip the hose with the other and squeeze the handles together to force the tubing straight onto the nipple. Bad explanation I know but that is the best I can come up with.
You might be shocked at what came up on one of the Google searches with the different wording I used.
RSKY
This is close to what I am looking for but it is for only one type of fitting. It is a "push on tool". Now maybe I can find one and end this frustrating search.
   / Need tool to put tubing on nipple #5
Cant you just heat hose and easily slip it over barb nipple?
   / Need tool to put tubing on nipple #7
I tried that. Got a pan of water boiling then poured into a plastic cup (hose had Roundup in it) and soaked the hose for about five minutes. That is how I managed to get it over the first of three barbs.
RSKY
That tool set is over $300. Not what I'm going to pay to repair a sprayer that costs $60 to replace. And I would only need it once every 5-10 years. Looking for something cheaper. Maybe a Harbor Freight one use plastic Chinese special.
RSKY
   / Need tool to put tubing on nipple #10
As long as it won't cause a contamination problem, try a little brake fluid. It works wonders for me.
Zero Turn Mower (A59228)
Zero Turn Mower...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
