GPS smart fence dog collar
   / GPS smart fence dog collar #1
sea2summit
Super Member
Left coast of, GA
Kubota 1860->25D, MX5800, M4D
Anyone have one? Opinions?
I’m starting to have an issue with my Pyrenees wandering up to the pavement and getting in trouble and they’ve never respected a fence even if I wanted to build one around the property.
   / GPS smart fence dog collar #2
I would be surprised if a GPS based system is accurate enough for what you want. Even my car system is off by a few hundred yards every so often, and that has all sorts of algorithms to hold on to roadways.
The dog GPS systems that I have seen are for finding your dog(s).
All the best,
Peter
   / GPS smart fence dog collar #4
My neighbor uses a wireless one, her dog runs right up to the boundary, it truly is an invisible fence.
I installed the wire in the ground version 5 years ago but it is no longer necessary due to the age of the dog. It worked perfectly.
I have heard some have problems with determined males smelling a ***** in heat or dogs with thick coats not feeling the shock.
Do you have a link for the GPS version you are looking at?
   / GPS smart fence dog collar #5
Dogs can take the hit if they are determined enough for any reason (the fur really has nothing to do with it). A friend of ours issue was the dog leaving chasing squirrels (this dog was a short hair). Bad part is, the dog generally won't take the hit to come back to the house LOL
   / GPS smart fence dog collar #6
To the OP, no clue on my end sorry, but I am curious what you go with and how you like it. I was looking for a tracking system for the blue tick hound we have, thankfully he is past the part of being sneaky trying to leave our property.
I'm thinking along the lines of Ponytug with the accuracy of the boundaries set by the GPS.
My other concearn would be battery life on the collar and how you would know that the collar needs to be charged. If the dog is 24/7 outside, you will need to do something while the collar is off the dog an and charging. Dogs are smarter than we given them credit for, dog may realize without that particular collar on...
I would also think, like a standard ecollar, you will probably get what you pay for.
Did come across this one...
   / GPS smart fence dog collar #7
Another type is the wireless fence system. PETSAFE Wireless Containment System | Chewy (Free Shipping)
I've never used one but have been told they work pretty well, and you don't have the issue of them going through the fence and getting stuck on the other side.
I have also heard of idiots who forget to take the collar off when bringing the dog someplace, and not understanding why the poor dog keeps yelping as he gets zapped.
All the best,
Peter
Shoot, you must drive a car as old as my truck. Daughters Tacoma tells her she's in the wrong lane for the next turn.
I'm only beginning my research, but so far this is the one with the best reviews and I'm able to take advantage of several discounts...far cheaper than a fence but damn.
Why would they get stuck on the other side and get continually zapped when you take them someplace? My thought is if they are across the line they are getting the buzzer either way.
   / GPS smart fence dog collar #10
There's no line on these. Check out the link. You have a radio transmitter which warns them if thy get a certain distance away, then shocks them if they keep going.
   / GPS smart fence dog collar #11
I'm curious. Are you sure that your daughter's car will tell her that she is in the wrong lane? My car is pretty new, and it will tell you what lane you are supposed to be in, but it's up to you to know whether you are in that lane.
I would also be leery about the accuracy of the collar, but I don't have any experience. It doesn't surprise me that it's expensive. Just a plain GPS collar is far from cheap.
My personal preference is just basic training to teach the dog to listen and not wander off. I have used a regular zap collar to support that training, but that is for later stages of training. It's for when the dog already *knows* the verbal commands, but he is not yet convinced that those commands are *always* more important that anything else in his environment.
Good luck.
   / GPS smart fence dog collar #12
Ok, I admit one of the GPS units is over a decade old, but the other is only a few years old. Phones, in particular, use added inputs like local WiFi networks, and accelerometers to further refine the estimated location that aren't available on a dog collar.
I think that there are extenuating circumstances for the GPS, in terms of how they do the math to arrive at a fix, and some of the math approximations that are in use.
However, my basic point is that under ideal conditions, consumer grade GPS units are +/- 3m (9ft) horizontally, which is tough on a dog in a yard, especially when those limits wander with differing satellite constellations and geometric fixes. (Imagine the poor dog; "WTH? I could get to the rose bush this morning...")
The invisible fence solutions have the advantage for the dog and dog training, that the boundary doesn't wander. (Not pushing that solution, just looking at it from the dog's perspective.)
All the best,
Peter
Good luck.
Yep, drives me bonkers because it starts like a mile out and reminds you every 20 or so seconds.
And as far as obedience, Pyrenees are not known for their abilities at obedience training.
All the best,
Peter
I think +/- 50 would be plenty for me, they've got a big buffer between the property line and where I don't want them to go so even if the "fence" was the property line and it was off +50 they'd be far from danger. I'd also assume speed plays a big role, not like the dog will ever reach 50mph, so the GPS probably get's a better chance at a good fix. My biggest concern is just that it works if I'm gonna dump that much money in one.
   / GPS smart fence dog collar #15
The bigger question IMO is how it works after a couple of years use. The assumption is it will work when you first use it, because the manufacturer knows that if you have problems within in specified warranty time frame, they have some obligation to make it right.
You're the guinea pig;)
Please keep us updated.
Per the product you noted at looking at, it has a one year warranty. For that kind of coin, I'd be all over the performance vs expectations like flies on crap.
   / GPS smart fence dog collar #16
I'm quite interested in this tread. I have someone looking for a system right now. I hate that the reviews in Amazon on getting worse. MANY of the pet containment systems there are giving free stuff for the 5 star reviews.
I worry about the details of these systems as I've heard many stories. Some systems will send a continuous tone when the dog gets close to the edge. That's a major flaw that I've heard of smart dogs getting around. The dog learns to walk till it hears the tone. Once it hears the tone, it sits down and waits till the battery dies then it knows it's "allowed" to go wherever it wants.
The wireless ones are relying on a signal strength. This is going to vary under lots of conditions. It seems the dog is not going to learn where it's boundary is. If the dog goes outside the range where the collar gets the signal, does the collar just start to shock it? What if the dog is near the transmitter and the transmitter gets unplugged? OR is it only shocked at a certain strength of the signal? Too many things could go wrong where a dog is shocked for no reason. THAT'S BAD!
I'd love to hear from real people that have these.
   / GPS smart fence dog collar #17
   / GPS smart fence dog collar #18
BTW for wireless fence, use clippers on the dog's neck where the collar goes, especially for dense coat pups. Also note that some collars come with longer studs that you can swap in.
My experience with wireless fences is with cats - and I can tell you that cats won't respects a wireless fence unless there's something to slow them down at the wireless fence in the first place. I have the wireless fence to keep my cats from investigating the (often compromised) main fence, but there's one place where the wireless crosses a couple hundred feet of grassy area that has no fence. A few times I had one cat end up across it, unwilling to come back over (meowing piteously) - she'd probably run across in the bad direction chasing something.
The solution there was to double the fence - it goes across, over 10', then comes back, then over 10' more, and finally across again. Makes a zone of pain as opposed to a single line, and she hasn't crossed it again since.
More recently we adopted a stray, and to get him used to the wireless we had to put up a temporary "real" fence on that grassy area because even with the whole "zone of pain" thing he preferred to cross it rather than face one of my other cats... at least I hope the "temporary" aspect of it is temporary...
   / GPS smart fence dog collar #20
@ning - Do you herd cats ? :)
That implies some level of control on them - I think you've got it backwards!
More seriously though, we lost too many cats (possibly to bobcats and mountain lions, but most probably just to coyotes) and so for the last 10 years we've had the radio fence which doesn't just keep them in the yard but it keeps them at least ten feet away from the fence as well so they're that much less interesting to something that may be able to come over the fence, too.
Adding a 7½' fence with a couple hot wires up high has helped to keep climbers out as well (and deer, too!).
Jack Daniels Miniature Decorative Truck (A59231)
Jack Daniels...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
