2020 Max 26XLT shuttle Loader won’t engage into float mode.
   / 2020 Max 26XLT shuttle Loader won’t engage into float mode. #1
tbcucci
2020 Mahindra Max 26 Shuttle
I have the new style Joystick by the seat on the right side. When trying to move the stick forward to engage the float it does not engage into float position? I have had the tractor for a year now and never used the float mode. I did have a problem with very slow bucket dump roll and the dealer adjusted the joystick cables in the body of the joystick. I wonder if that is why it won’t engage?
Thanks
   / 2020 Max 26XLT shuttle Loader won’t engage into float mode. #2
doesn't it still have a warranty?
Yes it does have warranty still. But being an old millwright, machinist, mechanic, welder, rigger, engineer without paper, crane operator, and Jack of all trades, I would still like to know if anyone else has had this problem and what was the fix. I kinda like doing a little of my research before loading up and going to a dealer that I may or may not have faith in? I’m kinda thinking that the dealer may be the reason for the float not working as it is now.
   / 2020 Max 26XLT shuttle Loader won’t engage into float mode. #4
You should feel the lever toggle past the normal limit and "snap" into float. It's a detent position. Do you feel it go into a detent and then nothing happens, or does it not even go into detent position?
BTW, make sure you are pushing hard enough to engage the detent. I recall other first time posters with this issue who were simply not pushing hard enough. The Max series has always has lousy loader controls, so don't expect finesse.
If it's not going into detent, that should be simple to diagnose. I'll wait to hear your feedback either way.
   / 2020 Max 26XLT shuttle Loader won’t engage into float mode. #5
short of pilot valve controls, aren't they all identical?
No it does not detent at all? No change in feel or position. Manual says it has float. Joystick has a float symbol on top. I pulled up the stick boot and looked at the cable ball ends and all looks normal, no damage, cables move freely? Hmm?
   / 2020 Max 26XLT shuttle Loader won’t engage into float mode. #7
push straight forward, its straight up on mine, it has to go pretty far
   / 2020 Max 26XLT shuttle Loader won’t engage into float mode. #8
The detent is part of the valve body, not the cables or lever mechanism.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
